02-26-2019, 09:51 PM | #1 |
Any 20+gal rear fuel tanks
First let me say that this forum is invaluable. My 71 fleet side long bed is now ready for a rear fuel tank. Is there a 20+ gallon fuel tank that can be put in the frame that can be done WITHOUT notching out the cross sill on the bed?
I have not been able to find any in my research. I really do not want to cut on the bed since it has already been painted. |
02-26-2019, 10:10 PM | #2 |
Re: Any 20+gal rear fuel tanks
You've got a pick-up truck. Put a 300 gallon Boyd Welding tank in the bed, put a valve to the lower tank, turn it on when you need to fill it?
1970 C10 LWB Stepside 1971 Dodge Dart 1993 Buick Roadmaster Estate Wagon |
02-26-2019, 10:23 PM | #3 |
That is creative! I was hoping to do this with just one tank and within reason on price. Some where around $200.
02-26-2019, 10:59 PM | #4 |
I put an EFI swap tank in my 68. Holds 20 gal. Its made for a 1970 chevelle, SPECTRA GM34TFI. There is info in my build thread page 3.
02-27-2019, 10:37 PM | #5 |
saw one today on the brothers website 26 gallons..
02-28-2019, 01:05 AM | #6 |
02-28-2019, 01:13 AM | #7 |
02-28-2019, 08:25 AM | #8 |
02-28-2019, 07:01 PM | #9 |
Just to have another perspective for anyone who finds this thread. Here is the LMC 21 gallon tank($150) with the TANKS PA-4 kit($236). The PA-4 kit gives you the Walbro 255lph pump, NPT threads to connect to fuel lines that can be easily adapted to AN fittings, and not to mention a baffle tray to prevent fuel starvation. This was the route I ended up going on my build mainly because of the lower cost, large capacity tank, in-tank setup for my LS efi engine, and easy install. The fuel tank baffling tray was just a bonus!
The side fill doesn't interfere with the the frame rail. It fits like a glove and you keep your cross supports. And depending on your setup, you can notch the bed support rail pretty easily to go over the top of the tank without issue. For install details see my build thread. Total cost = $386 Tank info: http://www.lmctruck.com/icatalog/cb/full.aspx?Page=56 http://67-72chevytrucks.com/vboard/s...8&postcount=41 PA-4 info: https://www.summitracing.com/parts/tnk-pa-4 http://67-72chevytrucks.com/vboard/s...&postcount=105 Cons = Tank hangs lower Still a lot cheaper than the expensive tanks though!
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". Last edited by TA_C10; 02-28-2019 at 07:09 PM. |
02-28-2019, 07:50 PM | #10 |
Thanks TA_C10! You just answered my question and a lot more with your fuel pump set up as well. I’m planning for an LS engine as well.
02-28-2019, 08:06 PM | #11 |
Thank you for the info on the 21 gallon tank in the rear.. I will be going that route. I would also like to add an additional tank as well. what options are available for a second tank not located in the cab.
Also what would be a good way to switch between the tanks and would there be a good option to mounting two gas guages for dual tanks... I willl be doing fuel injection on my setup. Michael |
02-28-2019, 08:35 PM | #12 |
02-28-2019, 08:45 PM | #13 | ||
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". Last edited by TA_C10; 03-01-2019 at 12:50 AM. |
02-28-2019, 09:50 PM | #14 |
Yep. The early Spectra tanks had issues but I have had no problem with this one and it is baffled. Also run a similar tank in my 64 Chevelle and it has no trouble either also it is baffled. I use the Corvette fuel pressure regulator mounted inside the frame rail above the rear axle.
02-28-2019, 10:13 PM | #15 |
I believe the issue with the LMC in-frame tanks is no baffles. That's one of the main reasons I went with a Boyd Welding tank, despite the cost.
02-28-2019, 10:34 PM | #16 | |
03-01-2019, 12:35 AM | #17 |
Sorry guys, I didn't see that type of tank you were using obviously.... I just assumed it was an older gm tank.... Disregard my reply on that...
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
03-06-2019, 12:15 AM | #18 |
