Old 02-26-2019, 11:15 PM   #1
rcazwillis
Starter gear
Newer style, smaller starter. After the truck starts, it sounds like the flex plate taps something a couple of times. Then quiets down at idle. Revving does not change anything. When accelerating, it makes a similar sound, but less aggressive. It looks like the starter gear does not retract all the way into the starter housing. When I push on it, the gear goes back far enough so the leading edge is inside the nose come. When I release pressure, it drifts back out a bit. Shouldn't this stay inside the nose come?
Shiming it does not change anything. Right now,I have more than 1/8" between ring gear starter shaft. Probably too much.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 02-27-2019, 01:29 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Starter gear
I had one break the fork that retracts the bendix. And it would bounce off the flex plate and make a horrible racket.
Died after a wiring order malfunction with some extended cranking.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 02-27-2019, 04:07 AM   #3
toolboxchev
Re: Starter gear
Flex plate bolt not tightened enough or has a washer under it.
toolboxchev is offline   Reply With Quote
Old 02-27-2019, 10:42 AM   #4
rcazwillis
Re: Starter gear
No washers. Possible one is loose.
Zane's 71 Build
Old 02-27-2019, 01:54 PM   #5
toolboxchev
Re: Starter gear
The stock ones have somewhat of a small or shallow/short profile. I believe they are a grade 8 with a fine thread. If they stick out too much they will tick or knock against other equipment like the starter and such.
I have seen it before, not tightened enough, or loosened up ticking on the starter.
Hope this helps! Flex Plate to Torque Converter Bolt to be specific.
Old 02-27-2019, 10:19 PM   #6
Mike C
Mike C's Avatar
Re: Starter gear
The unsupported nose Hitachi style starters come with a spacer ring that moves the drive gear further away from the flexplate.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-27-2019, 10:38 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Starter gear
Found the video of what my starter did.
https://youtu.be/g-pkemjgaPs
Old 02-28-2019, 10:11 AM   #8
rcazwillis
Re: Starter gear
Interesting, it was just sliding back and forth. Mine does not do that.
Zane's 71 Build
Old 02-28-2019, 01:29 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Starter gear
Yeah, still started a 454 fine. Just randomly bounced off the flex plate made an awful racket.
Old 03-03-2019, 08:04 PM   #10
rcazwillis
Re: Starter gear
While fixing a leak on the rear, I swapped back in the old flexplate. First thing I noticed was the ring gear was centered on the starter opening. The other was closer to the starter. I think the new flexplate had the ring welded on off center. Starter sounds much better.
Zane's 71 Build
Old 03-03-2019, 09:49 PM   #11
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Starter gear
Good you found it. Chasing noises and vibrations is frustrating
