Old 02-27-2019, 05:51 PM   #1
tednet
Most painless way to fix bent front brake backing plates on a 1962 c10?
Long story short, the truck was transported twice without wheels. The back brake backing plates are good, but the front ones on the 1962 c10 have a bent lip on the bottom.
I need to make it a roller and I can't put the brake drums (which have the wheel studs) with the bent backing plates.
All the rusty brake hardware is getting trashed. I see two bolts. Will removing those let me take the backing plate off or is it more involved? Can I even put the drum on without a backing plate?
Is removing the spindle in order to straighten the plates a better approach?
Where can I even buy a replacement backing plate if I end up cutting out the lip?
Anyone ever tried using a big hammer and straightening them out while still on the car?
Honestly, any advice and tips are appreciated it. I just need to get it rolling.
Full size images: https://imgur.com/a/AvYuyrs
tednet is offline   Reply With Quote
Old 02-27-2019, 08:05 PM   #2
Wrenchbender Ret
Re: Most painless way to fix bent front brake backing plates on a 1962 c10?
You could take a torch or hacksaw & cut the bottom off of the backing plate. Then watch for a good used one & replace it when you rebuild the brakes.
Wrenchbender Ret is offline   Reply With Quote
Old 02-27-2019, 08:10 PM   #3
nsb29
nsb29's Avatar
If your not going to use them a BFH should give you enough clearance
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 02-28-2019, 11:17 AM   #4
tednet
I ended up taking out all the brake hardware. Turned out the backing plate wasn't as tough to work on as I thought, a big hammer was enough to get it back to almost normal. Thanks for the input, everyone!
Old 02-28-2019, 11:57 AM   #5
demian5
demian5's Avatar
I'm thinking in this order (done it a few times):
1. Screwdriver
2. Huge channel locks
3. Crescent wrench
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
