How do the side marker lights work?
From my best reading of the diagrams, they are wired as below. This small diagram only shows one side of the vehicle. The other side of the vehicle should be a near duplicate of it.
But, this method makes no sense. The side marker light is never grounded. Am I missing something pretty important, or what's going on here? |
Re: How do the side marker lights work?
That circuit is not accurate whatsoever. It just shows you a very generic method of operation but is not specific and how it should be wired.
It might not be accurate, but it's the best I could come up with from the following link.
http://www.73-87chevytrucks.com/techinfo/wiring_diagrams/81-87_frt_light.jpg Like I said, it doesn't make any sense how it could work, but I don't have anything else to go on. Can you explain the correct method of wiring it? I'm wiring this truck from scratch. |
Doing some more reading, I'm confident I got it correct. I just don't understand why it works like it does.
It does look though, like I cannot use LED bulbs in a couple of positions here. I haven't thought through it enough to see which ones have to remain incandescent. My diagram was only intended to be a very simple one that breaks it down to the most basic components for easy understanding. It was not supposed to be accurately depicting the whole front wiring harness. |
It does do a good job of explaining how the side markers blink out of phase with the fronts while being lit when the turn signal is off.
When just the running lights are on, the side marker uses the heavy turn signal filament as the path to ground. The side marker is low enough current that the heavy front turn filament stays dark, cold and low resistance. When the front turn signal goes hot, the 12v balances out the 12v on the side marker and the side marker goes dark while the front bulb is lit. The front park light filament probably has enough cold resistance that the side marker stays mostly dark when the front turn is blinking while the running lights are off. Things like this are why bad grounds are always a good suspect when lights aren't working correctly. |
#6 | |
Moderator
![]() Join Date: Oct 2008
The GM wiring diagrams are in my signature and they are year specific... I'm not sure I'd use LED bulbs in anything other than the backup lamps. I don't care if the license plate is lit any better than it was originally. Not my boggle if people can't read it when it's lit to original specs. Tungsten filament bulbs do quite nicely in the other positions. It is possible to have the brake and turn bulbs be too bright.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
my whole truck is now led every spot and love it .
the front fender marker / turn just need a NON-polarity sensitive led bulb is all for it to work correctly . reg parts store ones do NOT work correct in this position . its not on this site but i have a super write up and tons of pics over on www.ck5.com in this thread . https://ck5.com/forums/threads/l-e-d...lights.335580/ if i get some extra time i could copy and paste and load the pics here and make a thread on this site . with out seeing pics you can skim my thread and get the best ones as i posted links in all the posts with good stuff or posted the name and style of the good stuff .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
![]() Join Date: Jun 2015
Not to hijack the thread, but in regards to side marker lights, is there supposed to be a gasket behind the marker light? My 79 PU has no gaskets for the side marker lights, like you would have for tail lights or front signal lights.
#9 | |
I'm inclined to just wire my side markers straight to the park lights, and skip all the trouble of making them "winkable." |
all factory . flash when turn signal is on and if headlight/markers are on flashes also with turn signal .
#11 | |
Moderator
The side Markers on my 1970's VW Rabbits flashed. My Dart Demon side markers flashed as well. IIRC my 78 Power Wagon marker lamps flashed. Same function as the turnsignal chevrons on the GMT800 side mirrors and the amber lamps on the T900 & K2 side mirrors. My Jetta has mirror turnsignal bulbs as well. I'd just run 168 tungsten peanut bulbs in the markers and be done with it. They last many many many many years. The peanuts in my 1969 Polara are more than 20 years old and they work just fine.
and with todays crazy drivers i say the more flashing the better . if you remove that function and get in a accident they might be able to get you on this with a good lawyer if someone know it was to be there.
