02-27-2019, 10:32 PM | #1 |
How to remove/replace the intermediate steering shaft rubber boot
I bought an Omix-Ada 18018.06 Steering intermediate shaft rubber boot to replace my old one. But I wanted to ask what is the best way to get the old boot off. Hopefully I don't have to disassemble the whole U joint part just to put this in but please let me know
03-01-2019, 05:31 AM | #2 |
Re: How to remove/replace the intermediate steering shaft rubber boot
Pry out the keeper snap ring, and pull off the shaft housing and pull off the little ears. Then slide off the rubber boot. Lots of grease inside the housing. Then have it zinc plated or black oxide plated. Hope that helps.
B.B |
03-01-2019, 09:38 AM | #3 |
did you have to press out the pin to get the new boot on?
03-01-2019, 11:22 AM | #4 |
No
03-01-2019, 11:26 AM | #5 |
No you have remove the snap ring
03-01-2019, 12:00 PM | #6 |
ok I'm just surprised that the new boot will stretch over the pin
03-01-2019, 01:46 PM | #7 |
That mean it does or doesn't? Maybe some heat and dish washing liquid?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-01-2019, 01:48 PM | #8 |
According to blazer bill it will but I'm skeptical. I haven't tried it yet
03-01-2019, 03:44 PM | #9 |
Post a picture of the end of your intermediate, where the boot will go.
03-01-2019, 09:23 PM | #10 |
I'm very interested in the way BlazerBill did his because I've restored about a half dozen of these and I press the pin out, take the old boot and clip off, slide the clip and boot back on and then press the pin back on. I don't think the rubber boot will slide over that pin without stretching it out of shape or ripping it.
03-01-2019, 10:03 PM | #11 |
Yes the pin needs to be press out. Sorry for that omission.
B.B. |
