Rollin' Member
squeeky ride
i hear it over my exhaust when i am rolling slow.
is this where a chasis lube comes in to play? forgive the greenhorn question, but of all my rides i have never had to deal with curing a squeek. cheers ![]()
:: 1977 C10 cheyenne :: :: 1973 new yorker brougham :: for sale - $1,500 lofat productions |
Professional Grade
Could be your speedo cable, mine makes a horrible racket at most all speeds until it warms up...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Rollin' Member
hmmm, i was thinking the suspension, but what do i know.
![]() all i do know is that i sound more like farmer bob than i feel comfortable with. hopefully getting my dual exhaust done tomorrow, i'll ask then as well. thanks.
Robert Olson Transport
![]() Join Date: Oct 2002
the things that come to mind are squeaking bushing in the control arms ( upper and lower) you can usually lubricate them to eliminate the squeak, a bad bearing on the driveshaft ( the one that bolts to the crossmember) the brake pads being worn so the wear indicator is scraping although thats more of a squeal that disappears when you apply the brake a bad coil spring seat that has some metal on metal or even a bad shock bushing ( replace shocks therye cheap enough) you have someone push up and down on the vehicle while you stick your nose around to try to isolate it
I'll second that squeaky speedo . Thought my front wheel
bearings were going bad. With my bad hearing and no carpet ,this truck is like a tin can. Hard to pinpoint noises. Unhooked my speedo cable and the squeak is gone ! A day or two later .....man , seems like its been a long time for that mileage to increase..... as my gas gauge doesn't work. OH !! ![]()
1979 Chevy Stepside 250-6,auto. 1981 Suzuki 850 70's Chopper,Springer,hardtail,750 Suzuki engine '84 Stang-wife's |
u joints
ok i have a Yamaha snowmobile but with a Cat heart can i be in both clubs |
LED King
My speedo cable used to jump around and squeak and make noise when it was cold. Took it out and lubed it with lithium grease and hasn't happened since.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
Rollin' Member
thanks for the responses. given me several good ideas on places to check.
i thought it sounded like spring squeek, but i dunno. i'll check it all. i know when i would go to the mechanic they would always offer a chassis lube. i guess i was hoping for a quick fix heh ![]()
LED King
Could also be a bad body mount. I'm having problems with one now.
