Old 03-01-2019, 07:28 PM   #1
Streetglide2015
Stock exhaust system question
My 1964 C10, with 283 2bbl has been retrofitted with a "true dual" exhaust system with what looks like Cherry Bombs on each side. I really don't care for the noise, and would like to return it to bone-stock exhaust.
Did this truck originally come with the single-exhaust (two into one) pipe? Single muffler also?
If anyone knows what the original stock configuration was, please let me know.
Thanks!
Streetglide2015 is offline   Reply With Quote
Old 03-01-2019, 10:10 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Stock exhaust system question
I gonna guess and say it was built with a 2 into 1 exhaust...all you really need to do is swap out the mufflers for a set of quite ones..and itd be cheaper..unless you just want to go with 2 into 1..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-02-2019, 01:32 AM   #3
Captainfab
60-66 Nut
Yes a 283 originally came with a single 2" exhaust. I'm not sure why you would want to restrict your engine like that. I would just replace both of your mufflers with something to meet your sound requirement. And if the tail pipes do not go all the way to the rear of the truck, extend them so that they do. That will help reduce the noise in the cab.
Old 03-02-2019, 08:39 AM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
https://photos.google.com/share/AF1Q...dGTjRKUGdPdWZB
Old 03-02-2019, 09:28 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
There was an earlier thread on here where someone came up with this info for a stock exhaust:
Old 03-02-2019, 12:45 PM   #6
Streetglide2015
Great advice everyone, and thanks for the drawings! Exactly what I was looking for! I will probably just change out the mufflers to something more toned-down, and leave the "true-dual" pipe setup.
Old 03-02-2019, 05:29 PM   #7
ybnaford
Junior Member
ybnaford's Avatar
Here are pics of my 62' setup, came original with a 283 config (bad block though) 350 to replace, which I eventually changed out to shorty headers with duals. This was to get the truck up and running for inspections and registration which I had all the parts to begin with. Then upgraded all the exhaust items.
04' Silverado 1500 ExtCab, 4x4, SWB - 240,000 & still Going, 62' C10 SWB, Stepside - Ole Green Girl!
ybnaford is offline   Reply With Quote
Old 03-02-2019, 09:35 PM   #8
AcampoDave
AcampoDave's Avatar
i just swapped out my worn out glasspacks on a true dual system. I went with Walker Dynomax 16" lenghth turbos clear out the back on my 283.. Research led me to believe they were the among the quietest of all performance mufflers. I like it, but if you're looking for "quiet as stock" they are probably not the mufflers for you. You still hear 'em but they wont leave your ears ringing after a long drive.
AcampoDave is offline   Reply With Quote
Old 03-04-2019, 12:38 PM   #9
Streetglide2015
Thanks for the input and pix! With so much combined knowledge here, it's great to tap into it!
