Speed Thingie
Does anybody know where I can get one of these speedometer converters?
![]() ![]() Mine seems to be worn out enough that the gears don't always engage. (No speedo function.) . I'd like to find a new replacement rather than a used, possibly worn out one.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 Last edited by saxart; 03-01-2019 at 08:15 PM. |
Re: Speed Thingie
![]() Join Date: Oct 2009
Re: Speed Thingie
$50 BIN https://www.ebay.com/itm/Stewart-War...nzx:rk:14:pf:0
$64 BIN https://www.ebay.com/itm/Stewart-War...TlC:rk:44:pf:0 $65 BIN https://www.ebay.com/itm/Stewart-War....c100005.m1851 $59 BIN https://www.ebay.com/itm/Stewart-War....c100005.m1851 Note that they have different compensation ratios, so make sure you get what you need. |
Who Changed This?
![]() Join Date: Jan 2013
Re: Speed Thingie
The 1.2020 is probably the ratio. I'd open it up and see if it is a reducer or speedup ratio. I'd guess speedup, since 1.2020 is greater than 1. Easy to tell- the gozinta gear will be bigger than the gozoutta gear.
Post Whore
![]() Join Date: Feb 2016
Re: Speed Thingie
I love technical talk.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#6 | |
How did I get this OLD!
![]() Join Date: Dec 2014
Re: Speed Thingie
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
Re: Speed Thingie
Resurrecting an old thread here, but I just switched from 3.73 gears to 3.08 gears and my speedometer reads slow. I need an increase of about 21%, which would mean I would need a 1:1.20 speed increase adapter, correct?
I'm also under the impression there are two types, direct drive and reverse rotation? Is that true? I'm looking for a direct drive if that's the case. Would something like this work? https://www.ebay.com/itm/NOS-Interna...-/353049721296 Edit: I should clarify, I've got the SM465 transmission. Last edited by Indyuke; 11-06-2020 at 03:22 PM. Reason: Add info |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Speed Thingie
Don't bother with a used ratio adapter. Buy a new USA made example for your application for about $100.
See my post here: http://67-72chevytrucks.com/vboard/s...&postcount=995 Edit - sorry just caught that this is a resurrected post. Yes, you need a 1.21 or so ratio.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 11-06-2020 at 06:08 PM. Reason: edited |
