Old 03-03-2019, 05:10 PM   #1
RBW
RBW's Avatar
Rear shock hack job
I've attached pics of the rear shock mounts on my '62 C10. There's been quite a bit of modifying done by the previous owner. I've been told the Diff might be out of a Blazer. The shock mounts are some of the shabbiest work I've ever seen. The basic location seems ok, but I want to cut all of the PO's disaster out and do it right. Any suggestions for top and bottom mounts would be greatly appreciated. As you can see, I'll be starting from scratch.
RBW is offline   Reply With Quote
Old 03-03-2019, 06:26 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Rear shock hack job
I'd try to get it back to stock.
The 60-62 stock shock location is a great setup. The 63-66 guys will often relocate their shocks to something like the 60-62's.
I'll see if I can find a thread.
66 C20 Service Truck:
Old 03-03-2019, 06:32 PM   #3
LostMy65
LostMy65's Avatar
This might be a good option :
http://67-72chevytrucks.com/vboard/s...d.php?t=477839
Old 03-03-2019, 07:01 PM   #4
LostMy65
LostMy65's Avatar
Another thread and webpage :
http://67-72chevytrucks.com/vboard/s...d.php?t=763851
http://nolimit.net/tech-center/67-c1...on-kit-1963-72
Old 03-03-2019, 11:58 PM   #5
62bagger
62bagger's Avatar
It looks like they moved the shocks to the inside of the frame. On my 62 they are on the outside of the frame. They left the bottom shock mounts on the trailing arms but they are turned to the front. Can you turn the bottom mounts to face the rear will they move them back to the outside of the frame? if yes you can use the No limits top mounts top mounts. Hope this helps.
62bagger is offline   Reply With Quote
Old 03-04-2019, 01:51 AM   #6
RBW
RBW's Avatar
Thanks guys. This gives me a couple of directions for looking into.
Old 03-04-2019, 07:40 AM   #7
PGSigns
PGSigns's Avatar
With the two sets of saddles on the housing I think the housing is out of a 63 up truck. Post a picture of the center section and that will help id the rear.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-04-2019, 03:16 PM   #8
RBW
RBW's Avatar
I’d definitely appreciate an I.D. on this differential.
Old 03-04-2019, 04:16 PM   #9
1998c1500
1998c1500's Avatar
There should be a code on the top of the passenger side axle housing that will tell you what it came out of and the original gear ratio.
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
1998c1500 is offline   Reply With Quote
Old 03-04-2019, 04:25 PM   #10
RBW
RBW's Avatar
I’ll look for that. Where could I find the code key?
Old 03-04-2019, 06:39 PM   #11
1998c1500
1998c1500's Avatar
The 1st letter is plant ID. 2nd designates gear ratio. The 4 numbers following that are the date code. If you list it here someone will help
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
Old 03-04-2019, 08:32 PM   #12
nsb29
nsb29's Avatar
I hope he didn’t do to much work on the rest of the truck
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 03-04-2019, 08:53 PM   #13
LostMy65
LostMy65's Avatar
Looks like a 63-72 12-Bolt
Is it 6-Lug or 5-Lug?
Old 03-04-2019, 11:11 PM   #14
RBW
RBW's Avatar
It's a 6-lug.
The only thing I see stamped on the top of the passenger side axle housing is an "N".
Old 03-05-2019, 12:43 AM   #15
Captainfab
60-66 Nut
Being a 6 lug, and with that panhard bar mount, it will be a '65-'70 truck 12 bolt.
Old 03-05-2019, 12:44 AM   #16
RBW
RBW's Avatar
I did find a second letter stamp. It was about a foot away from the "N" and it looks like they failed to get a good strike, so gave it another go...
Old 03-05-2019, 08:39 AM   #17
nsb29
nsb29's Avatar
You can figure out what gear you have by counting of the rotation Pinyan as you make one revolution with the wheel
Old 03-05-2019, 10:41 AM   #18
1998c1500
1998c1500's Avatar
They are hard to see on some differentials, but it should be there. Try sanding the area in the pic.
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
Old 03-06-2019, 01:21 AM   #19
Captainfab
60-66 Nut
If you want to know what gears are in the differential and whether it is a posi or open diff, just pull the cover and have a look. There's no telling what could have been changed in the past 50 years. More than likely the oil needs changed anyway since a differential is one of the most neglected parts of a vehicle. It'll only cost you a couple quarts of gear oil, a cover gasket and a little time. Then you will know exactly what you have and the peace of mind knowing that your differential has fresh oil.
Old 03-06-2019, 03:07 AM   #20
RBW
RBW's Avatar
Good idea. So I just count the teeth on th ring and on the pinion, and do the math?
Old 03-06-2019, 07:48 AM   #21
PGSigns
PGSigns's Avatar
The numbers will be on the ring gear. Will look like 41-11.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-06-2019, 08:33 AM   #22
1998c1500
1998c1500's Avatar
I think he is looking for the year not the gear ratio
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
Old 03-06-2019, 01:36 PM   #23
demian5
demian5's Avatar
I just went through the exact same thing on a 60.
1st pic - Had a diff from a 80-90s cop car.
2nd pic - Got one from a 64 truck and had to add the wider saddles for the 60, and remove the track bar mount from the diff. Luckily the saddles were able to be welded on right next to the narrower ones (just like yours) and I used the existing ones to get the pinion angle correct.
3rd pic - Used the CPP deluxe track bar kit that put the pivot on passenger the trailing arm. Issue was that after installing that, no way I could put the shocks back in the factory locations. Had to extend the shock mounts as shown.
It all worked out but what a chore. Whomever put the car diff in used a conversion u-joint so all I had to do was use a factory u-joint and the driveshaft bolted right up. Before and after pics included too. Im running 1" spacers on the transport wheels on the truck to get them centered.
The diff you have in there should work. It looks like a 65 or later truck 12-bolt. The hard work is done. Just get a better shock arrangement. If you have the mounts at the rear of the frame, you could turn the lower mounts around and just bolt up some shocks.
Message me is you have any questions.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-06-2019, 02:19 PM   #24
RBW
RBW's Avatar
I spoke with someone at No Limit, to ask if the shock relocation mounts he sells for 63-66 trucks could be modified to fit my '62. He said his were based on the OEM mounts from '62, and advised I try to make mine work. So I flipped the lower shock mounts around to the correct direction, and it's looking like they'll do the job.
That was good advice on the Diff. I'll pull the cover, read the gearing marks and freshen up the fluid and gasket.
Another area of funk is the springs. They appear to be OEM units that were heated in order to lower the truck. I like the truck's stance, so would like to replace these with correct aftermarket springs with the same ride height. Can you guys take a look at the attached pic and tell me how much this truck has been lowered?
Old 03-22-2019, 02:12 AM   #25
RBW
RBW's Avatar
Still trying to figure out a good way for mounting my rear shocks. Please forgive my crappy drawing, but hopefully, it illustrates a point I'm trying to make. Everything I've learned about suspension and shock mounting tells me the shock should run roughly parallel to the arc of the rear wheel travel. The idea of mounting shocks that mount toward the rear places the travel of the shock outside that arc and it seems to me they will loose a lot of damping effectiveness. My sketch shows roughly where I'd like to mount my shocks, so they are inside the arc of rear wheel travel. Do any of you have photos that show a clean and sturdy way of mounting shocks similar to this?
