03-04-2019, 01:43 AM | #1 |
AN Fittings
Wanna Convert My Rubber Heater Hoses To Braided To Match The Rest Of My Engine Compartment. How Do I Do That At The Heater Core?
New To Using Braided Line and These Fittings. Thanks Posted via Mobile Device |
03-04-2019, 08:44 AM | #2 |
Re: AN Fittings
You'll want to use fittings that just hide the clamp. They really don't make a fitting to just slip over the heater core tubes. You would have to get a hard line an fitting and then put a inverted flare on the tube to make it a true an fitting. I've a provided a picture from summit of the style of clamp that would be easier for what your wanting to do, its for reference only, you'll want to check your hose size.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
03-04-2019, 10:55 AM | #3 |
Re: AN Fittings
Like this:
http://www.titanfittings.com/Product...IaAgXkEALw_wcB They are compression by male AN just order your size required and attach them to the copper heater core lines. |
