Air Cleaner Duct Tubing
Anyone have a p/n or source info for replacement air cleaner inlet ducting? Since these trucks had the round to oval transitions, I'm curious if there was an aftermarket duct-hose that adapts easy enough.
Please..... No 'wrecking yard' recommendations. 99% of any squarebody in a yard is plucked of useable stuff these days if you can even find a yard w/a square. If you're lucky enough to actually find a square, the heat/elements typically render the same quality plastics under hood that we're trying to repair.
![]() ![]() Join Date: Jul 2002
Re: Air Cleaner Duct Tubing
LMC had it for V8 models last time I looked. The 6 is slightly smaller and did not see that size in their catalog.
I got my OEM air cleaner duct for my 83 C20 from a place called Vintage Parts.
They sell some obsolete original car parts and even parts for old appliances. You must have the GM part number to search for parts on their website. My duct was not cheap (about $35 as I recall) but it was the correct duct for my truck. |
Thanks for the suggestions.
I need one too for duel air cleaner I had one keep going yards and boards could no find one so I order one from LMC after two years of looking. There a little thinner made.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
OutOfMyMind & I'llNeverKnowWhy
The LMC one looks like the pre-TBI air cleaner as it lists 1981-86. Has anyone found the TBI style ducting?
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
They have both order the right one you need. I got the long straight one. Not the TBI! because I running two tubes to the duel air cleaner to get more air in.
