11-25-2003, 01:03 PM | #1 |
350 to 454
I'm tring to decide how hard it is to swap a 454 into a 71 3/4 ton that used to have a 350. It is a 4X4 and has a 4 speed. Do i have to do anything to the frame (cutting, grinding etc) I've heard that some guys have trouble with the valve covers hitting the ac components on the firewall? Do i use the stock 350 motor mount towers? Do i have to dent the firewall to get the dist to fit?
Sorry for all the questions, just tring to decide if all the work will be worth it. Thanks David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
11-25-2003, 01:17 PM | #2 |
Resident Curmudgeon
I think it comes down to:
Do you want to do a body lift or reposition the tranny/xfercase. If mounting in small block position, you have cab clearance issues, if moving xfer case, you have driveshaft tranny linkage issues. Yukon Jack is installing a BB. I think he opted for the body lift.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
11-25-2003, 02:11 PM | #3 |
Recovering 67-72 Addict
The other stumbling block in your case will be the clutch linkage. I mocked a big block setup in a 71 4spd 4x4 and even after moving the mount on the frame so that everything would line up I had interference problems with the exhaust manifolds. I think that Yukon Jack is using a hydraulic clutch setup to work around this.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
11-25-2003, 02:14 PM | #4 |
So, would it be a whole lot easier if i went with an automatic?? Or would i still have problems with clearances?
Thanks for the help DAvid
11-25-2003, 02:17 PM | #5 |
Automatic is much easier. That, I have successfully done.
