03-04-2019, 08:40 PM | #1 |
Brown and white 24 gauge wire/ign switch
I just took my switch down to see why I have no wipers and maybe no accessory (key turned to the left) power. I found a small brown and white wire with no spade female connector, just a bare wire hanging there. I think that it may have been tucked under the spade connector for the big brown wire that connects to the outside spade on the back of the switch.
I'm thinking of just soldering it to the brown wire. But i'd like to know the correct position for this guy. I can't figure out the wiring diagrams. I wish I had a clear picture of the switch with what goes where. Is there such a picture somewhere? Thanks, Brian Edit: I see this explained by VetteVet here. http://67-72chevytrucks.com/vboard/s...d.php?t=735184 So i guess the small brown and white should be soldered. I have a stock external regulator and HEI ignition if this matters.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 03-04-2019 at 09:05 PM. |
03-04-2019, 08:55 PM | #2 |
The Older Generation
Re: Brown and white 24 gauge wire/ign switch
Check this thread out and see if it helps. http://67-72chevytrucks.com/vboard/s...d.php?t=469854 LockDoc
03-04-2019, 09:37 PM | #3 |
OK, got it. Looks like the brown and white wire pulled out of the connector crimp. Now reattached.
However the wipers still don't work and i recall that they stopped working the last time I replaced this switch some years ago ( very little rain here last 5-6 years). Time to look into this because we are actually having a winter this year.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
03-05-2019, 01:54 AM | #4 |
Try this thread for the wipers. http://67-72chevytrucks.com/vboard/s...d.php?t=413551 Ours are the 2 speed wiper motors. There is information all the way through the thread..... LockDoc
03-06-2019, 12:23 AM | #5 |
Much thanks LockDoc.
