Old 03-04-2019, 09:02 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
What's the deal with Delco Spark Plugs?
71 C-10 402
Getting around to replacing the spark plugs on the project, and have to ask, how can spark plugs be difficult?...............EDIT, Because, I forgot my heads are off a late 60s HP 396The rest is nonsense.......
I picked up Delco R44T from Napa, and checked out the part number, but I can't start the threads. The old plugs (Autolite) and the Delco are a 9/16" fine thread 18, but if anything the old threads are cleaner. They install with ease, and no issues since originally installed, 15-20 years ago.
Delco is a shorter thread and doesn't take a lock washer I guess. I don't recall seeing them without one, but I suppose they work - assuming you can install them to begin with
So what the heck? Possible the Autolite compromised the threads in the heads somehow? I've installed 3-4 sets of new plugs since I've owned her, never a problem.
Edit: Interesting. AP 404 Autolite doesn't cross reference to R44T, same vise versa. Something is peculiar. Ah SNAP!, I just remembered my heads are HP off a late 60's Corvette or Camaro. I wouldn't expect so, but that's got to be it.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
Last edited by 71CHEVYSHORTBED402; 03-05-2019 at 01:36 AM. Reason: Oooooooooops. Left for entertainment "value".
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-04-2019, 09:35 PM   #2
weq92f
weq92f's Avatar
Re: What's the deal with Delco Spark Plugs?
The difference is the date of manufacture of the head. Earlier heads, prior to 70 I believe, have the straight threads with the washer. Later heads have the newer style threads which do the sealing themselves.
If you select plugs for a 68 Chevrolet Camaro SS w/396, you'll get the right ones!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-04-2019, 09:40 PM   #3
Grumpy old man
Grumpy old man's Avatar
Two different spark plugs for two different style heads .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 03-04-2019, 09:43 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
I deleted my previous post after looking at you old plugs again. You did not get the correct plugs from the parts store. Those are for a SBC, which I believe did have tapered seat plugs in 1970. You need plugs with the 3/4" "N" designation reach, and not tapered seats, but the compressible washer like on the old plugs.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-04-2019, 09:44 PM   #5
71CHEVYSHORTBED402
BINGO!..................Ha, I used to know that...Been so long since I replaced the spark plugs. And I'm getting old
Tony
Old 03-05-2019, 05:56 PM   #6
tdangle
tdangle's Avatar
Earlier heads used a flat surface with a washer on the plug. AC plugs are numbered such example R44T is resister plug 44 heat range T designates flat sealing surface with washer
R44ts as used in later heads R is resister 44 is heat range and the ts is taped seat
Correct me if I'm wrong.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 03-05-2019, 10:10 PM   #7
RichardJ
oy vey !
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 03-05-2019, 11:58 PM   #8
71CHEVYSHORTBED402
Originally Posted by RichardJ View Post
oy vey !
So much for the idea they're 9/16"-18 threads. Pretty close I guess
Tony
Old 03-06-2019, 01:15 AM   #9
tdangle
tdangle's Avatar
oy vey !
Thanks for the info. Never too old to learn
Terry
Old 03-07-2019, 02:22 AM   #10
burnin oil
Now have fun and go to Autolites web page and try and figure out their nightmare. Especially when it comes to crossing regular plugs with the race applications.
burnin oil is offline   Reply With Quote
Old 03-07-2019, 09:38 PM   #11
cleszkie
cleszkie's Avatar
A cross thread provides the best seal possible I'd keep trying with the wrong plugs until they catch. Then crank 'em in with a cheater bar!
cleszkie is offline   Reply With Quote
Old 03-07-2019, 10:07 PM   #12
zicc1835
zicc1835's Avatar
ruff crowd
zicc1835 is offline   Reply With Quote
Old 03-08-2019, 01:12 PM   #13
71CHEVYSHORTBED402
Couldn't get em to start, even after taking a sledge hammer to them. Thought I had em, but the plugs just break in half. I may try some epoxy
Tony
Old 03-08-2019, 10:09 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Now that’s solved what’s the deal with AC Delco making plugs in China
Old 03-08-2019, 11:54 PM   #15
palallin
Drill out the holes, shove the plugs in, and weld those puppies in place!
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 03-09-2019, 12:18 AM   #16
71CHEVYSHORTBED402
Was thinking that - right after I mentioned epoxy, ha ha, imagine if you didn't do it right A weld is permanent
Tony
