Old 03-04-2019, 10:32 PM   #1
72 k15
72 k15's Avatar
78 axles in 72?
Will a 14 bolt axle and dana 44 out of a 78 fit in a 72 gmc k15? Wanted to buy them for the 4.10 gearing they have and put em in as a upgrade. Looks like i saw the front will go right in but the rear perches will need to be moved?
72 k15 is offline   Reply With Quote
Old 03-05-2019, 04:31 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 78 axles in 72?
I think your correct..the fronts will bolt right in...rear spring perches will need moved....just pull a tape on the rear center2center on both and it'll let you know...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-05-2019, 05:02 PM   #3
72 k15
72 k15's Avatar
Re: 78 axles in 72?
I was wondering Beacuase the guy I am buying them from says they will just drop in.
Old 03-05-2019, 05:31 PM   #4
mongocanfly
Post Whore
Re: 78 axles in 72?
I know my 91 k20 14bolt and my 67 k20 eaton are different width spring pads....
The front swapped with no issue...had to move the rear spring pads...I'd just git him to measure it to compare it to yours...moving spring pads isn't a big deal...just cut the old ones off and weld on a new set..
And the wms 2 wms is different as well...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-05-2019, 07:42 PM   #5
Jeff's bowtie's
Re: 78 axles in 72?
The 3/4 ton14 bolt will require spring perch relocation and a 1 ton 14 bolt is a direct bolt in
Jeff's bowtie's is offline   Reply With Quote
Old 03-06-2019, 09:43 PM   #6
72 k15
72 k15's Avatar
Re: 78 axles in 72?
Forgive me but what does wms mean? And could I just weld the perches to the angle on the old axle or do I have to do some double knot ciphering to get it rihgt?
Old 03-06-2019, 09:53 PM   #7
sweetk30
sweetk30's Avatar
Re: 78 axles in 72?
wms = wheel mount surface .
srw = single rear wheel .
drw = duel rear wheel .
c&c = cab & chassis . narrowest width rear of the 14ff .
14ff = 14 bolt full floater axle .
there is srw and drw then drw c&c for 14ff axles .
so if you can post up pics before you buy so we can help you get the correct stuff .
and if no lift kit or stuff like that then yes you can weld the perches to the same angle as the old axle .
there is super beefy aftermarket leaf spring perches out there that work better than old and are cheeper than new stock style wimpy ones . and no need to save the old when there so cheep .
barnes 4x4 has them . sells a lot on ebay .
ruff stuff specialtys has them .
diy4x.com has them .
offroad design has them .
some places have axle swap kits with perches / spring plates / u-bolts / shock mounts all in 1 package deal .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-06-2019, 09:56 PM   #8
Mike C
Mike C's Avatar
Re: 78 axles in 72?
I built a lightweight jig off my original perches to align the shock mounts then i just put the new perches on at the same pinion angle as the original setup at the original width.
No measurement origami.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-06-2019, 10:17 PM   #9
72 k15
72 k15's Avatar
Re: 78 axles in 72?
Picture from the seller.
Old 03-06-2019, 10:37 PM   #10
mongocanfly
Post Whore
Re: 78 axles in 72?
14 bolt full floater...I also see some front axle parts laying in the floor along with rear axle parts..are you buying them in the torn apart state?....I would be Leary of something somebody tore apart and stuck back together....unless I really knew the axle owner...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-06-2019, 10:48 PM   #11
72 k15
72 k15's Avatar
Re: 78 axles in 72?
I am kinda Leary also he wants 350 for Dana 44 and 14 bolt only want them for the 4:10s would be cheaper than rebuilding mine. So I see I need to move the perches then?
Old 03-06-2019, 11:06 PM   #12
mongocanfly
Post Whore
Re: 78 axles in 72?
I'm gonna say yes..spring perch needs moved..and probably the shock mounts as well...only way to know for sure what needs done is pull a tape on it.....
Something else I wonder about is the driveshaft length.....
also the total axle width will be wider (I think) than your axles...if you've got a Eaton axle seems like I saw that gears aren't being made for the anymore....( again,I think)... ..
350 is cheap enough...but it would scare me that he tore them apart..and why...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-06-2019, 11:32 PM   #13
72 k15
72 k15's Avatar
Re: 78 axles in 72?
I honestly don’t think all that would be worth it I might just put some 4:10s in my axles instead. Who makes some rebuild kits and gears that won’t take my wallet unlike Yukon, although if they make good stuff might buy from them.
Old 03-06-2019, 11:38 PM   #14
mongocanfly
Post Whore
Re: 78 axles in 72?
Do you know what axles you have...front and rear...?....Yukon makes great stuff
What gears do you have now?...also tire size and trans you have?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-06-2019, 11:48 PM   #15
72 k15
72 k15's Avatar
Re: 78 axles in 72?
Danna 44 and 12 bolt Orginal Posi gearing tag says 3.07. Going to be running 33s and nv4500.
Old 03-07-2019, 12:11 AM   #16
mongocanfly
Post Whore
Re: 78 axles in 72?
You'll have to change the rear diff/locker as well to go from 3.07 to 4.10s...12bolt series 3 to series 4..
Your close with your ratio choice...I'm running 33s with a nv but I went 4.56s
Youd be better off buying the axles already setup from another truck...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-07-2019, 01:51 AM   #17
kwmech
Re: 78 axles in 72?
Installing the 14 bolt, aside from moving the spring perches, you will also have to move the shock mounts and mess with the parking brakes cables. You will also have to freshen up the rear driveshaft and install either a conversion joint or just go 1350 series with the driveshaft mod.
Old 03-07-2019, 02:08 AM   #18
burnin oil
Re: 78 axles in 72?
I have to second the Barnes4x4 stuff also. I used there jeep kit to install a Ford 8.8 in a Jeep TJ. Kit was outstanding other than the directions for locating the brackets. They also sell on Amazon. That is where I bought the kit at since it was actually the cheapest there.
burnin oil is offline   Reply With Quote
Old 03-09-2019, 06:00 PM   #19
72 k15
72 k15's Avatar
Re: 78 axles in 72?
You said I have to get different carriers I thought Yukon made 4.10s that fit the 3.73 and down carriers front and rear?
Old 03-10-2019, 08:31 AM   #20
mongocanfly
Post Whore
Re: 78 axles in 72?
not sure about Yukon but I think Richmond makes what they call a thick gear 4.10 for a series 3....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-10-2019, 10:16 AM   #21
Mike C
Mike C's Avatar
Re: 78 axles in 72?
Several manufacturers make the thick gears. But I would take advantage of the opportunity to upgrade to the 3/4 ton axles if it were mine. And I did with a set of 4.10 geared axles from an ‘86 3/4 ton Suburban. I used the semi-float rear though. After breaking 6 different 12 bolts one way or the other in my Jimmy this has been one of the better upgrades I have done. You may have to shorten the driveshaft if you aren’t running any lift in your truck, but I would recommend drilling a new locator hole in the spring perch and moving the rear axle back one inch. That better centers it in the wheelwell any how. You will be paying to have custom shafts made for both ends anyhow when you swap the NV4500 in.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-20-2019, 08:58 PM   #22
El Dorado Jim
Re: 78 axles in 72?
Like someone else said, you will have to move the spring perches and the shock mounts are different also,and have to be moved, I did this in my 72, not that big of a deal, but the shock bolt holes are bigger on the 3/4 ton axle, I just welded a washer on each side of the shock mount that had a little smaller hole in it....
El Dorado Jim is offline   Reply With Quote
Old 04-08-2019, 04:18 AM   #23
scott123
Re: 78 axles in 72?
The shock mount holes are often forgot on this swap.
I have both welded washers, cut hangers and replaced them as well as ordered them from a race car shop such as Stockcar products, etc..
Good call, the small details of the shock mount hole is often overlooked.
Scott
scott123 is offline   Reply With Quote
Old 05-30-2019, 12:19 AM   #24
ClassicJimmy
FNG to resto/mod world!
ClassicJimmy's Avatar
Re: 78 axles in 72?
I'm in the process of doing the same thing, mine is 75 K25 into a 71 K5, & I'm wondering if there is any other parts from the K25 that would be an upgrade? ie - power steering box, brake booster. I also noticed the K25 has a front swaybar but the K5 does not. Should I keep the swaybar? Thanks for any advice, fellas!
71 GMC Jimmy - under construction
75 GMC K25 Sierra Grande - under deconstruction
92 Chevy K2500 ECSB - sold
04 Nissan Titan ECSB Off Road - sold & missed
13 Ford F-150 Ecoboost (work truck) - sold
16 Ford F-150 Ecoboost (work truck)
ClassicJimmy is offline   Reply With Quote
