Old 11-25-2003, 01:22 PM   #1
orange72350
orange72350's Avatar
new carb ideas
im looking for a new carb. really thinking about an edelbrock 600, with vacuum secs and electric choke. need 2 know of these thigns are any good, adn whether er not theyneed a lot of screwing around to make them run right. any pros/cons, or ideas for other carbs are much appreciated.
thanx
dale
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 11-25-2003, 01:28 PM   #2
jbw0127
DEMON
I've had very good luck with Barry Grant's Demon carb line. Always work very well out of the box and they come with great instructions, including a "how to" video. They have many applications from small displacement street motors to all out big cube race motors. They are also very good looking carbs........Just my 2 cents!
72 swb Cheyenne
"nut & bolt" frame off (in process)
Blown 383
jbw0127 is offline   Reply With Quote
Old 11-25-2003, 01:54 PM   #3
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Go with the Edlebrock... Great out of the box performance and they are a set and forget it carbs......
67Fleetsidedream is offline   Reply With Quote
Old 11-25-2003, 01:56 PM   #4
cdowns
cdowns's Avatar
get the edelbrock i've had mine 2years not a problem
Old 11-25-2003, 02:25 PM   #5
doughby82
doughby82's Avatar
i bolted my on right out of the box,and i have never adjusted it.runs smooth.also i liked it because there isnt any gaskets on the bottom end
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 11-25-2003, 07:04 PM   #6
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
I've put the same 600 CFM, electric choke Edelbrocks on a 1970 Nova, 1969 C10, and a 1971 C10 all with 350 cu in engines. The result? They're all working without a hitch!
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 11-25-2003, 07:31 PM   #7
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I've had my Carter (now Edelbrock) for 10 years or so. Once I got it tuned with the right rod/jet combination I havn't had to touch it, except for an occasional preventative maintainance cleaning.
You should keep you carbs clean to prevent wear and tear where the linkages come thru the carb. Vacuum leaks suck, literally.
Cat Fuzz is offline   Reply With Quote
Old 11-25-2003, 07:53 PM   #8
dinnut
dinnut's Avatar
i was wondering about this myself as i would like to go with an aftermarket intake and carb and stick my 4bbl on the 72 that has a crappy 2bbl on it.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
