Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 03-05-2019, 02:11 PM   #1
Afirehawk1
66 C10 Battery Cables w/396 BBC
Would like some input on this one.
I placed my 66/67 Chevelle BBC engine in my 66 C10.
Looking for a set of battery cables.
Thinking using the Chevelle cables in the truck but was concerned on the lengths being correct.
Any experience with a similar setup?
Thank for any input
Keith
Afirehawk1 is offline   Reply With Quote
Old 03-05-2019, 06:58 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 66 C10 Battery Cables w/396 BBC
To take any guess work out of that issue, I make all of my battery cables from welding cable. Most welding suppliers also sell the appropriate sized terminals. It's also fun using the hammer lug crimper to take some frustrations out on.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-05-2019, 07:09 PM   #3
Macdaddy1
I went down to auto zone and bought the length of cable and the pellets that you heat up in the connector and melted my connections on and cut cable to desired length.
Macdaddy1 is offline   Reply With Quote
Old 03-06-2019, 07:53 AM   #4
PGSigns
PGSigns's Avatar
If you want pre made cables I use an old extension cord with the ends cut off and run it along there I want it to go. Then measure that and get one close at the parts store that has the ends I want on it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-06-2019, 07:59 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Jimmy
Now see I never thought of that, we learn something new every day here. I've been using an old role of 1/8" solder I've had laying around for twenty or more years.
Old 03-06-2019, 11:46 AM   #6
kens65fb
Jimmy
Most of the cables I see are 4GA.
Is that heavy enough for a stock C-10, without air-conditioning or electric fan ??
kens65fb is offline   Reply With Quote
Old 03-06-2019, 11:53 AM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yes. Ideally the more strands the better but 4GA is fine. Make sure your ground strap is the same and connected to a good, clean spot on the engine block. Then run ground straps to the frame and body, if possible from the same spot on the block. Bad grounds are the #1 electrical issue that will cause so many of the most random issues people have.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-14-2019, 11:05 AM   #8
kwmech
I know I'm not a vendor but I've got a lot of bulk cable and ends if you need something custom made up to double 0
