03-05-2019, 05:35 PM | #1 |
Hydroboost Pushrod Removal
Does anybody on here know how to remove the pressed in hydroboost pushrod? I purchased a new GM Unit and want to install an adjustable shaft with a clevis on the end. I have heard rumor of a Kent Moore tool that is used to pull the pushrod out of the socket. Anybody on here have experience with that?
03-05-2019, 06:17 PM | #2 | |
Re: Hydroboost Pushrod Removal
I had to make a shorter one for my application (Cadillac). I am sure I put a sleeve over the rod, clamped the rod with vice grips and used a pair of pry bars to pop it out. It came out very easy too. I just made a new one from a 3/8 grade 8 bolt, threading the clevis on the thread and machining a new ball in the lathe. Works perfect Good luck. |
03-05-2019, 08:30 PM | #3 |
so you are not just prizing on the shaft you have to remove a retainer pin also?
03-05-2019, 08:42 PM | #4 | |
The crimp is only required for assembly, once installed the the rod is going nowhere if the lengths are all correct. |
03-05-2019, 11:10 PM | #5 |
The version I have isn't swedged in but has a retaining ring made of some kind of hard-core semi flexible nuke proof death plastic.
I put the unit in a vise and used a very long 3/8 extension thru the ring and plenty of a$$ to pop it out. Very scientific. Make sure you are getting a nice straight pull inline with the rod or you will get a hernia and it won't come loose and you will want to smash things with a big hammer. Have fun.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
