Front Axle swap
Hey Folks,
I'm certain this has been asked many times on here. I'm planning on swapping my front axle from my 69 K10 with drums to a 74 front axle with discs. What can or what could be expected when I do this? Will there be problems mating any of the steering components? I'd like to gather all the parts I need before I attempt the swap. Any info would be great. Thanks! |
#2 | |
Re: Front Axle swap
'71 ![]() '86 K30 C&C '89 Iroc-Z |
Re: Front Axle swap
IMO when you do a axle swap the most important part is getting your leaf spring perches in the right spot. You will need get a scarfing tip and cut the perches off and weld them in the proper location giving you the proper yoke angle. Might need to relocated shock mounts as well. Make sure you google what your yoke angle needs to be to give you the proper driveline angle. On my rear axle swap I believe it was like 1 degree up. As far as proportioning devices Id say run it and see what it does. I thought I was going to have to put one in my K20 but I ended up not.
These are just my thoughts and maybe give ya a few things to think about. I am in no way an expert. Good luck my friend! |
#4 | |
All about them K’s
![]() Join Date: Jun 2014
Re: Front Axle swap
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Oct 2018
Re: Front Axle swap
I just swapped mine about a month ago and it bolted right in with no issues. I have to figure out the sway bar mounting yet, as the front crossmember is different than the square body, but very easy swap. I had to buy both drag link ends to go from the steering box to the pitman arm. Get 3/4 ton 2 wheel drive brake hoses. I got some from rockauto for a 76. They fit good and I even put a 2” suspension lift on while I was doing the swap. Don’t forget the proportion valve for disk drum. I had to change the brake lines from 1/4 to 3/16 also.
Re: Front Axle swap
The '69 has different steering. I'd swap a '70-up steering box/pitman arm/adjustable drag link assembly.
