Old 03-05-2019, 09:40 PM   #1
daveshilling
daveshilling's Avatar
Found a very cool, well made frame mount brake bracket
Gents,
Tomsclassic on ebay has apparently found a box of old hardware they haven't produced in years, and they're up on ebay.
These are 55-59 frame mount brake booster brackets that use the stock pedal location. They are very heavy duty! I picked one up for my hydroboost brake setup I'm working on. Only caveat is they come with no instructions and Auto City has no advice on installation.
It closely resembles a bracket I've seen DIY on the forum here.
There is a bracket that lines up with the stock pedal and appears to extend/lower the mounting point for the rod... not sure why it was included, but someone must've felt it was necessary. I think it would certainly allow you to chop the height of the pedal, which makes this bracket even more valuable !
LINK TO THE BRACKET ON EBAY
daveshilling is offline   Reply With Quote
Old 03-05-2019, 10:25 PM   #2
MiraclePieCo
MiraclePieCo's Avatar
Re: Found a very cool, well made frame mount brake bracket
Well designed, pretty self explanatory even without directions. I like it!
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 03-06-2019, 01:51 PM   #3
daveshilling
Here is a picture of the bracket. I can take measurements from mine if anyone needs them for a DIY.
Old 03-11-2019, 06:32 AM   #4
Hughmullersa
Greeting From South Africa
I would appreciate the dimensions if you are offering , sometimes these part just cost way to much to import
Hughmullersa is offline   Reply With Quote
Old 03-11-2019, 01:28 PM   #5
jwhotrod
flatout-engineering.com sells that bracket setup as an accessory to their corvette suspension setups for our trucks. I have one that I bought from them with the master cylinder, etc.
jwhotrod is offline   Reply With Quote
Old 03-13-2019, 04:04 AM   #6
daveshilling
I haven't seen just the bracket for sale on their website..and I'm glad I didn't because the ebay one I found is on clearance!
Old 03-13-2019, 04:06 AM   #7
daveshilling
Sure, I'll take some measurements and post them up.
I also know you can just use the old master cylinder to locate the pedal as well, in case thats easier. I tossed mine awhile ago so that wasn't an option.
