Old 03-05-2019, 09:44 PM   #1
Timtruck
twiste dframe
It looks like my the rear of my frame might be a little out of whack, '92 short, the front of the bed sits level with the cab lines but the rear bumper sits about 1 inch higher on the right and its noticeable when looking from the rear to.
I can tell there used to be a frame mount hitch on it and it was on a farm for a while so maybe it was worked a little too hard one day...
Timtruck is offline   Reply With Quote
Old 03-06-2019, 09:27 AM   #2
sntrym95
sntrym95's Avatar
Re: twiste dframe
Check the bumper brackets and the bed supports. Without a pic I'd guess that a bed support is collapsed and likely not the frame as the bed supports are significantly thinner than the frame rails.
Mike
sntrym95 is offline   Reply With Quote
Old 03-06-2019, 12:21 PM   #3
Big Daddy Bear
Big Daddy Bear's Avatar
Re: twiste dframe
Do you get a level bubble when you check the tailgate section as well?
If so, I would give the bumper & brackets a hard first look.
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 03-07-2019, 07:25 AM   #4
Timtruck
Re: twiste dframe
All looks good under the bed, no collapsed supports and I get the same reading on the level with the top of tailgate and top of bumper.
Gonna need to take measurements on both sides and mark when they start to really change. the bed needs to come off when I put in new cab corners so I'll wait till then to get a better look and try to figure out how to fix it.
Old 03-10-2019, 09:57 AM   #5
Timtruck
Re: twiste dframe
I think this might be on my mind a little too much when I am lying in bed thinking of how to build and anchor spot in my garage floor to straighten it....
Or I could build on the driveway because it needs replaced anyway.
Old 03-10-2019, 04:51 PM   #6
sntrym95
sntrym95's Avatar
Re: twiste dframe
Seeing as how the bumper brackets bolt to the frame, I don't think you have a frame issue. If the frame was bent, the bed and the bumper would both be out of whack. Since it's just the bumper, I'd look at the brackets, one is probably bent a little.
Mike
Old 03-10-2019, 07:00 PM   #7
Timtruck
Re: twiste dframe
No, the bumper and the bed are parallel with each other, I noticed the this when I measured the wheel arch before lowering it and the left rear sits almost one inch higher than the right and it's noticeable looking at it from behind.
Old 03-10-2019, 07:57 PM   #8
sntrym95
sntrym95's Avatar
Re: twiste dframe
Then I would look at the suspension as well. Those leaf springs may have taken a beating and will wear out before the frame twists. You probably have a broken or worn out spring pack.
Mike
Old 03-10-2019, 09:07 PM   #9
Timtruck
Re: twiste dframe
Well, a spring would be easier than frame work.
