03-07-2019, 12:02 AM | #1 |
Proportioning valve question
I am planning to run a manual disc/drum setup on my ‘64. I have a MC for a 71/72 non power truck and have a proportioning valve from my crossmember donor truck; it was an ‘83, and had power brakes to the best of my knowledge.
Can I use a prop valve from a power brake truck in my manual brake system? Last edited by dracko; 03-07-2019 at 12:35 AM. |
03-07-2019, 12:53 AM | #2 |
I am planning to run a non-power disc/drum setup on my ‘64. I have a MC for a 71/72 non power truck and have a proportioning valve from my crossmember donor truck; it was an ‘83, and had power brakes to the best of my knowledge.
Can I use a prop valve from a power brake truck in my non power brake system? |
03-07-2019, 01:18 AM | #3 |
Re: Proportioning valve question
When I did the same setup on my old 66 2wd I got a generic adjustable prop valve and plumbed it into the rear brake line. Worked great for several decades, and was nice to be able to dial in rear brakes depending on load.
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
03-07-2019, 01:25 AM | #4 |
Thanks man I definitely considered that, but tough to not use this OE one I got for free. If it won’t work I’ll end up buying a new one. Off-hand, do you know if there’s any rubber seals or parts in prop valves that could dry up or deteriorate over years of sitting?
03-07-2019, 01:38 AM | #5 |
60-66 Nut
Yes you can. The proportioning valve does not care if the line pressure is manual or boosted.
03-07-2019, 01:48 AM | #6 |
Ya, free is always good. No, I have no idea what's inside those things.
03-07-2019, 09:25 AM | #7 |
03-07-2019, 10:44 PM | #8 |
Nothing inside the proportioning valve (combination valve as GM calls them) that will decay other than a few O rings & maybe one cup. When you are ready to bleed your brakes make sure to remove the brake light warning switch and install the little tool that holds the shuttle valve centered. I've attached a couple of pics of a cutaway proportioning valve and the little tool that holds the valve centered when bleeding your brakes. The holding tool is made of plastic and is only like $5.00 if I remember correctly.
03-07-2019, 10:56 PM | #9 |
Food for thought - did you keep ALL the brake lines from your donor truck? the reason I ask is believe it or not the brake lines from a 73 - 87 C-10 will fit our trucks like they were made for them. I did have to make a bracket to mount the proportioning valve in the 73 - 85 location but other than that it all came together perfectly.
03-07-2019, 11:35 PM | #10 |
Wow thanks for all the info on prop valves and that tool for bleeding, never heard of one before.
I didn’t take any of the brake lines from the donor truck, but after seeing those pics and some of others trucks that have done the same that looks like the way to go. I wonder how brake lines from a power brake truck would work with my manual setup? Thanks again! Last edited by dracko; 03-07-2019 at 11:42 PM. |
03-08-2019, 08:54 PM | #11 |
They'll work too. Brake lines don't care about boosters either.
03-08-2019, 10:30 PM | #12 |
03-08-2019, 10:55 PM | #13 |
They fit, check it out. http://67-72chevytrucks.com/vboard/s...d.php?t=782830
03-08-2019, 11:03 PM | #14 | |
03-09-2019, 10:41 AM | #15 |
your system should work fine. I recently did a disc/drum swap from an 86 into my 64. I used everything from the 86 but went with a manual master cylinder rather than a power MC. Everything works great
03-09-2019, 10:51 AM | #16 |
03-09-2019, 12:20 PM | #17 |
