Chevy guy
![]() Join Date: Mar 2015
Question about 12 bolt axles
Hi,
I'm starting to work on my 65 rear brakes and noticed the axles have quite a bit of in and out movement. How much is normal? I haven't measured how much exactly but it is very noticeable, should I be worried? Thanks, Jon
Tehachapi, Ca 57 BBW shortbed 64 C30 service bed 65 C10 long bed fleetside 70 C10 long bed fleetside 74 C30 flatbed |
Post Whore
![]() ![]() Join Date: May 2015
Re: Question about 12 bolt axles
theres gonna be some side to side movement...1/8" or less I would think...contributing factors would be worn c-clips, crosspin, or side gears...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 03-07-2019 at 05:27 PM. |
Chevy guy
Thanks,
I'm doing a disk brake conversion so I'll be taking the axles out and I'll check those things. I have at least 1/8 inch on both sides so I'm going to see if I can tighten that up some. Jon
Never Ending Projects
I believe they do make c-clip shims to help with that but you want to make sure you don't have any other issues first.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
