Old 03-07-2019, 04:43 PM   #1
spudder
Active Member
Drop spindle typical problem...
Helping friend with his '65 truck project. We installed a set of dropped spindles for '73-'87 last week. Just finished up the brake lines today. Went to mount the 15x8 5 lug factory rallys and the wheels are rubbing the lower control arms.
I've read somewhere about trimming the control arms for clearance. Also read about it weakening the area around the ball joints.
What is the solution with running 15 inch wheels?
Absolutely want to stay with 15 wheels.
Does anyone make a 2 inch dropped spindle? Just dropping the truck with spindles in front and 3 inch coils in back. No lower.
Thanks for your help.
spudder is offline   Reply With Quote
Old 03-07-2019, 06:52 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Drop spindle typical problem...
Yes, CPP makes 2" drop modular spindles, that do not have this problem. This is why I recommend these instead of the normal 2.5" ones that most sell.
Here is with 15x8" 4.5" back space later GM factory wheels. 2" spindles will clear the arm
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-08-2019, 08:02 AM   #3
PGSigns
PGSigns's Avatar
I had to grind both my lowers to clear the 15X8 wheels. Whne I went to the smoothy wheels I got 15X7 for the front and a 225 tire and the clearance was much better.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-08-2019, 11:28 AM   #4
Robert Haas
It is a pretty simple fix to cut reliefs in the lower control arm and weld in a couple plates to re-establish the factory strength. I have done several over the years.
Robert Haas is offline   Reply With Quote
Old 03-08-2019, 01:42 PM   #5
verdell
verdell's Avatar
I ran 15 inch smoothies with Western Chassis spindles. Didn't have this issue with mine either.
verdell is offline   Reply With Quote
