03-08-2019, 01:18 PM | #1 |
Woodgrain Steering wheel trim?
Anybody know if there is a source for the woodgrain trim piece on our steering wheels? My truck came with the original steering wheel, but its missing the trim piece. I've looked high and low, but no luck? Thanks!
This is the part I'm referring to. Untitled by awesome_adawson, on Flickr
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
03-08-2019, 07:42 PM | #2 |
MOTORHEAD!
Re: Woodgrain Steering wheel trim?
Same question here...!
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
03-11-2019, 11:25 AM | #3 |
Count me in as well, need one for my 76
Current: 84 K30 3+3 SRW (2010), 76 C30 3+3 DRW (2015), 83 C10 Suburban (2018), 89 C20 3+3 (2018), 90 K5 (2019), 89 V30 DRW C&C (2019), 78 "Big 10" (2019), 83 K30 3+3 SRW (2020) Previous: 79 K20 Long Step (03-05), 91 R30 3+3 DRW (11-12), 83 K30 3+3 SRW (13), 86 K30 SRW (16-17), 73 C20 (18), 85 C20 3+3 (18-19), 80 C10 (19-20), 77 K5 2wd (19-20) |
03-12-2019, 03:55 PM | #4 |
I just purchased some 3M vinyl woodtrim. It's a great match. Here's mine:
03-13-2019, 10:29 PM | #5 |
I've never seen a source for new ones. I have one that I have been saving that the "woodgrain" is not in great shape but the metal itself is. These would be sooo easy to reman...i think. Should be ale to scan these and make them...somebody should be able to...I've been holding onto it for that reason, hoping I could find a place to make one.
03-14-2019, 03:21 AM | #6 |
Wow that looks sharp!! Do you happen to have a link?
03-14-2019, 03:23 AM | #7 | |
03-14-2019, 06:27 AM | #8 |
Here's 2 second of searching: https://www.metrorestyling.com/Searc...ge=1&cat=19978
Patience and an exacto knife is all you need. |
03-14-2019, 07:16 AM | #9 |
Lowe's and Home Depot also has rolls of the woodgrain vinyl.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
03-14-2019, 10:41 AM | #10 | |
03-14-2019, 04:02 PM | #11 |
I don't recall. I'd try a few of them.
03-15-2019, 02:03 AM | #12 |
03-15-2019, 09:20 PM | #13 |
I have one of those wheels from a 70s GMC van but the inlay or whatever is orangish not woodgrain.
03-18-2019, 03:13 PM | #14 |
Gm called that wood grain chestnut on the 1977 models. Not sure the name 76 down though.
03-19-2019, 11:47 PM | #15 |
Will do.
Thank you!
