Old 03-08-2019, 02:36 PM   #1
jwodahl
Modifying door panels
I have found it to be nearly impossible to find a set of door panels for a 92-94 suburban in blue, especially the drivers front.. here's my question: can I take a drivers door panel off of a 2 door model, and cut the hole bigger to accommodate the window control bezel a 4 door has? Thanks..
jwodahl is offline   Reply With Quote
Old 03-09-2019, 06:59 AM   #2
Re: Modifying door panels
I would think a truck door would work, but I am pretty sure the 2 door Blazer is a bigger door. Maybe a crew cab truck might work also.
Palf70Step is online now   Reply With Quote
Old 03-09-2019, 08:58 AM   #3
b454rat
Doors are all the same, and think the panel is too. But can't remember how the switches are orientated.
Old 03-11-2019, 09:24 AM   #4
Stormin08
Stormin08's Avatar
to my knowledge, the panel is the same. you will have to trim for the larger switch panel.
There was a set of suburban/ crew cab door panels in the classifieds,
Stormin08 is offline   Reply With Quote
Old 03-12-2019, 03:51 PM   #5
WILWAXU
Thumbs up Re: Modifying door panels
Yes. The truck front door panels are the same. Only difference is the switch panels.
I used Blazer/Yukon switch panels with my aftermarket (LMC) door panels in my regular cab truck.
John Brown
1990 Chevrolet C1500 Silverado
Regular Cab Step Side - 350 Auto
Ridetech StreetGRIP Suspension
Instagram @wilwaxu
WILWAXU is offline   Reply With Quote
