Old 03-08-2019, 05:49 PM   #1
MiraclePieCo
MiraclePieCo's Avatar
Wiper motor measurement please
Does anyone have an original vacuum wiper motor lying around? (I can't count how many I've tossed in the garbage after doing electric conversions)
I need a center-to-center measurement between the two studs on the rocker arm that's attached to the output shaft.
Thanks!
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 03-09-2019, 11:26 AM   #2
cmayna
Re: Wiper motor measurement please
I'm coming up with 2 inches OC. Per your pic, is that rocker plate original? Looks kinda homemade.
Craig
My truck '50 Chevy 3100-5 window
If I'm not working on my truck, I'm fishing with the wife or smoking Salmon.
cmayna is offline   Reply With Quote
Old 03-09-2019, 05:36 PM   #3
MiraclePieCo
Thank you so much! That's just a random photo off the web to illustrate the measurement I needed. I'm constructing my own electric wiper system, but it helps to know the factory geometry rather than use trial and error.
Old 03-09-2019, 09:52 PM   #4
cmayna
aha! Those posts are also 3/8" total in length with 1/4" of each shaft is dedicated for the wiper arms and then with a mushroom head at the end that helps contain the wiper are and the spring clip.
Craig
Old 03-09-2019, 10:01 PM   #5
cmayna
Here's a pic of my extra motor
Craig
