Old 03-08-2019, 07:42 PM   #1
dieseldawg142
dieseldawg142's Avatar
Crewcab door lock rods
just got my crewcab back from paint, went to lock it up and the rear door lock rod fell down the door.
when i fished the door lock rod out, also found this other rod laying in the bottom
Size:  16.9 KBName:  IMG_4023.jpg
i have taken these doors apart a few times, but have never had to screw with the lock rods.
as you can see, there is jack for access on the rear doors. i took the door handle out and tried to use a mirror and flashlight, but i can't make out a thing. tried to see how the other door is, but can't see nothing on it either.
looked all over online but can't find a diagram or anything about them.
was trying to avoid taking it completely apart again as i just put new window run, fuzzies, and 3/4 window seals in it.
anybody know how or where the big rod goes? the door lock rod seems to clip into a plate with a rod connected to the latch. thanks
dieseldawg142 is offline   Reply With Quote
Old 03-08-2019, 11:01 PM   #2
AntiGov
AntiGov's Avatar
Re: Crewcab door lock rods
That looks like the interior door latch rod . But could be the power door lock rod , separate from the manual door lock rod . Is that the original door ?
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 03-08-2019, 11:04 PM   #3
AntiGov
AntiGov's Avatar
Is that the door in question in your last pic ? If so it is prolly the power lock accuator rod.
If you dont have power locks , that rod would be better off in the garbage instead of rattling around making noise for the rest of your life .......lol
Old 03-09-2019, 02:27 AM   #4
dieseldawg142
ya, that is the door, and no, it's not the orig door.
it came from a '77 sub with manual winda's and locks.
i welded up the body trim holes quite a few yrs ago and stuck that fatmat all over the inside and out....don't recall the big rod being in there....
i have been trying to find a diagram or exploded view of a crew or sub rear door, but no luck
can't lock the rear door
Old 03-09-2019, 01:01 PM   #5
AntiGov
AntiGov's Avatar
I have an open rear power door . I will check it out
You may have to find a junk rear door for cheap and disect it
Old 03-09-2019, 01:26 PM   #6
dieseldawg142
thanks Gov
ya, i have the orig door from the truck, just may have to cut a hole in it so i can figure this stupid thing out...lol
Old 03-09-2019, 02:11 PM   #7
AntiGov
AntiGov's Avatar
Ok , looks like your short rod with door lock knob connects to a pivoting bracket. The long horizontal rod in your picture of the door is also conected to this pivoting bracket . On the other end of this long rod is another pivoting bracket . This bracket is located above your door latch assembly but not attached to it . This is where your mystery rod i believe attaches. It connects on one end of the pivoting bracket and runs down vertically and attaches to the door latch assembly. The difference i see between power and manual is the length of your mystery rod . On power that rod is longer . It runs past the door latch assembly and connects to a power accuator below in the door . A bracket attachement mid way at the latch assembly is then connected to this longer power window rod . This is where it appears your manual lock rod would end and attatch to the latch assembly. I dont know if i can get pics . Its tight
Old 03-09-2019, 10:11 PM   #8
dieseldawg142
yup, your right Gov, it does hook to the door latch and a pivot bracket to the left of the inner door handle
ended up cutting open my old door, and no, it was not really a savable door, entire bottom is rusted off and the next 4" up are full of bondo
what was screwing me up was the mystery rod fell out of the winda regulator with the door lock rod...how it got from the back of the door to the front of the door is beyond me...
anyways, just in case anyone ends up messing with the lock rods in their crew or sub rr doors, here's how it goes, like ya say, my mystery rod goes to the latch from a pivot bracket
what a total pia to get the rod clips on, can barely get my fingers in there and 95% of it was done strictly by feel, can't see a darn thing in the rr doors
worth the hassle, locks up beautifully now...coming together GOV
Old 03-12-2019, 05:58 PM   #9
v30crewcab
v30crewcab's Avatar
what color is that on your truck? it looks good. oops, found your other thread.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
