700R4 Source for '56 GMC?
I am in the process of planning to install a 700R4 into my ‘56 GMC 100 pickup that currently has a 455 Pontiac coupled to a TH400 followed by 3:73 gears. Have talked to some of the vendors but looking for feedback from the forum. Truck is just a cruiser with maybe 300 HP/400 lb-ft of torque fueled by a Quadrajet. Prefer to buy a good rebuilt unit from a reputable source either local or the ones advertised such as Phoenix, Performance Automatic, TCI, Monster, Transmission Depot, etc. Aware of the issues with the 700R4 and the parts needed for the install but would appreciate any information from those who have done the swap.
Re: 700R4 Source for '56 GMC?
I think you need and adapter to make the 700r4 work behind the 455. Not up on my Pontiac motors but thought they were different. I think some mid 80 olds had 700r4's with same bolt patterns. The better 700r4's that were built were the 87 and up models.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
For that hp/torque range - TCI Streetfighter 700R4
i have a http://www.phoenixtrans.com/ 700r4 in truk, i suggest you email them to see what they have
install was plug and play and has been in truk for the last 36,000 miles without any issues
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
![]() Join Date: Mar 2012
I would suggest a 2004R. The bellhousing fits BOP without adapters. The first gear ratio of the 2004R is more appropriate for the high torque of the 455. The transmission is inherently stronger than the 700R4 and it can be built to survive at very high torque levels.
https://www.jalopyjournal.com/forum/...ission.566029/ http://cpttransmission.com/2004R_trans_2to4.htm https://www.hotrod.com/articles/ccrp...mission-build/ http://extremeautomatics.com/th2004R.php#th2004r Last edited by 1project2many; 03-09-2019 at 05:54 PM. |
I can't help with the swap. But have used Performance Automatics with great success. They aren't far from you either. Go check out their place in person, it's impressive. Good luck on the swap!
1958 Apache 454ci 4 speed |
![]() Join Date: Jul 2007
I don't believe they ever made a B-O-P pattern 700 r4 case. If you have to have that trans rather than a 200R4 buy the thick adapter plate with the spacers for the converter snout and converer bolts. I've used both and the thin plates with the nuts welded to them leave a lot to be desired.
They run the 200R4 behind some real stout engines though.
#8 | |
