Old 03-09-2019, 09:16 PM   #1
2001convertable
upper power steering pump bracket
Hi, I was wondering if anyone would know if there's a company that makes a power steering bracket where the pump would sit up high.I want to keep the original generator in its original spot.I have a 235 6 cylinder. thank you
2001convertable is offline   Reply With Quote
Old 03-10-2019, 01:50 AM   #2
mr48chev
mr48chev's Avatar
Re: upper power steering pump bracket
I don't know anything about this outfit and the kit isn't just a bracket it is the whole setup to put the pump on the 235 and operate it. It shows an alterator but that should't be an issue. https://benchworksteering.com/produc...ring-pump-kit/
I see they have the compete kit but that is real spendy https://benchworksteering.com/produc...sion-gear-kit/
My ongoing truck projects:
Old 03-10-2019, 07:06 PM   #3
2001convertable
Im going to call them tomorrow. thank you so much
Old 03-12-2019, 12:49 PM   #4
_Ogre
_Ogre's Avatar
$350 for a simple flat bracket??? wtf?
if you can use a grinder and drill that bracket could be easily made for less than $15
shop air compressor timer
Old 03-12-2019, 01:49 PM   #5
mikebte
Would you be able to use the old style power steering pump on the rear of a generator? You may have already considered this.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 03-12-2019, 04:55 PM   #6
mr48chev
mr48chev's Avatar
That 350 buys a new pump, all the brackets and pulleys and I think the belt to do the install. Still a bit on the spendy side but it probably saves a day or two's worth of time hunting for the right pulley or searching for a belt or stopping to ask and wait for a suggestion for a fix.
As far as those generators with the pump go. I remember working on one about 40 years ago and swore that I would never upon never work on another one. Plus the guys who have that setup for sale usually think they are worth more than the cost of that kit.
Old 03-12-2019, 09:25 PM   #7
2001convertable
Mike, I was also thinking about if the old style would work. Does anyone know if it would with a modern type of steering box?
