Old 03-09-2019, 09:31 PM   #1
kens65fb
Tilt column
Looking to replace a crappy unknown automatic tilt column in my 64
The shifter is sloppy, and the key switch is just about shot.
What length is best for a 64
kens65fb is offline   Reply With Quote
Old 03-10-2019, 12:26 AM   #2
jrusher
Re: Tilt column
I used a 70s van tilt column in my 65. No key on column and you just drill out the pins on the lower male/female end of shaft to get correct length to couple up to your rag joint . I just picked up another one for the wife’s 61
jrusher is offline   Reply With Quote
Old 03-10-2019, 01:18 AM   #3
64shortbox
64shortbox's Avatar
Re: Tilt column
I did the same as jrusher. I used a tilt column from a 72 van, collapsed the shaft like jrusher did and slid the column down as close to the dash as I could to give myself more room than the factory column allowed.
64shortbox is offline   Reply With Quote
Old 03-10-2019, 07:34 AM   #4
kens65fb
Re: Tilt column
I see most have used a van column, but I'm assuming that they are hard to find these days.
If I go with an aftermarket column, what length is best.
Old 03-10-2019, 10:57 AM   #5
earl84
Re: Tilt column
Can’t tell you the length for an aftermarket, but another source for a used column is old RVs. Check your area for RV salvage lots.
earl84 is offline   Reply With Quote
Old 03-10-2019, 11:08 AM   #6
kens65fb
Re: Tilt column
No 70's vans or RV's in salvage yards in my area
I would like to use an aftermarket tilt wheel, has anyone used one??
If so what length is best
