![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
C20 disc brake conversion advice
I am a new member here seeking advice on disc brake conversion kits.
I purchased a C20 with totally inoperable service brakes and so would like to just convert to disc. What I am looking for is advice from members who have performed this swap, what kit they may have used & why one kit might be better than another? Thanks
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
#2 | ||
"I ain't nobody, dork."
Re: C20 disc brake conversion advice
Find a parting out or wrecked 71-72 C20 as they had disc brakes from the factory and swap everything over.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Who Changed This?
![]() Join Date: Jan 2013
^ Yup. That would be the least expensive way to go.
#4 | |
Then I would have a GM 14 bolt to address the lack of gearset availability for the Eaton axle & the rear brakes at the same time. Unless I am wrong then all I would need is a brake booster & master cylinder setup to fit the 67 (I don't think the 73up will fit) This would also give me other goodies like power steering Anything wrong with my thinking here?
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris Last edited by 67 twins; 03-13-2019 at 01:21 AM. |
Take the whole front crossmember from a square body. Drill holes where necessary. With disc you'll want power assist. The square body vacuum booster isn't a bolt in. Hydraboost is a worthy addition with a little fabrication.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
If you replace just the ball joints, the control arms are similar enough to work. I'd find a square body knuckle and use all of its brake parts. I'd recommend switching to power brakes as well, it'll be safer in the long run. I put all 1979 C20 brake parts on a '68 C20 a while back, just had to change ball joints to make it work. It's a pretty simple swap as long as you buy all the parts you need.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
My understanding is 71-87 trucks and up to 91 Blazers and Suburbans (still squares). Snag the whole thing crossmember and all. Bolt in drill a few holes.
There are tons of squares in scrapyards untouched because they made them for so long. |
