Old 03-10-2019, 12:24 AM   #1
Foureye71
Foureye71's Avatar
No Dash Lights
Hey all my truck lost its dash lights but all my other lights work as they should. Im by no means an electric wiz but ive tried some basic things like cleaning the part of the dash the light switch goes on and a new light switch.
Edit: forgot to mention they used to work but decided they didn't want to anymore a while back.
'71 K1500 Short-Wide
'86 K30 C&C
'89 Iroc-Z
Foureye71 is offline   Reply With Quote
Old 03-10-2019, 12:57 AM   #2
Curtb1971
Curtb1971's Avatar
Re: No Dash Lights
Couple things to check. There is a ground on the bottom lip of the dash that is clipped on the metal part of the dash (right behind the oil gauge). It is notorious for causing dash light issues. Clean up with a piece of sandpaper. Also check the pnl lts fuse on the upper right of your fuse panel for a blown fuse.
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 03-10-2019, 01:07 AM   #3
Curtb1971
Curtb1971's Avatar
Re: No Dash Lights
Ground wire and clip location
Old 03-10-2019, 01:42 AM   #4
Foureye71
Foureye71's Avatar
Re: No Dash Lights
Sweet Ill have to check those spots out tomorrow.
'86 K30 C&C
'89 Iroc-Z
Old 03-10-2019, 09:37 AM   #5
Mike C
Mike C's Avatar
Re: No Dash Lights
My experience with loss of dash lights is the rheostat coil breaks on the original headlight switch. I've lost two in the 30 years I've had my Jimmy.
Try rotating it through it's full swing a couple of times. Sometimes it's just a poor connection between the knob and the spring.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-10-2019, 01:20 PM   #6
Foureye71
Foureye71's Avatar
Re: No Dash Lights
Ive replaced the switch already but ill take another look at it just to be sure
'86 K30 C&C
'89 Iroc-Z
Old 03-10-2019, 08:56 PM   #7
bill3rail
bill3rail's Avatar
Re: No Dash Lights
As it was stated, check your ground!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 03-10-2019, 10:12 PM   #8
Foureye71
Foureye71's Avatar
Re: No Dash Lights
Ok so I got and checked everything that was suggested and I couldn't find anything that did not look right and my cluster still has no lights.
The fuse was wasn't blown and the ground clip and wire looked fine, but I did sand off the paint that was on the part of the dash it clips to. The switch also looked good.
The ground wire going to the printed circuit looked good, but I did clean up all the contacts on the connector. I did notice one ground screw on the printed circuit was loose in its hole so I replaced it with one that fit better. Im also missing a few sockets for blubs on the back side of the cluster, could that be causing the cluster to light up?
'86 K30 C&C
'89 Iroc-Z
Old 03-10-2019, 10:29 PM   #9
Curtb1971
Curtb1971's Avatar
Re: No Dash Lights
Hmm, not having some light sockets in wouldn't effect others working. I'm at a loss without seeing it. If you have some time to shoot up north this week I would be more than happy to take a look at it and we'll be able to hunt your electrical gremlin there.
Old 03-10-2019, 10:30 PM   #10
Foureye71
Foureye71's Avatar
Re: No Dash Lights
pic of connector to cluster. from a previous reply contact #7(far left) should be the ground
'86 K30 C&C
'89 Iroc-Z
Old 03-10-2019, 10:40 PM   #11
Boog
laying low
Boog's Avatar
Re: No Dash Lights
You've probably already removed the cleaned the harness to cluster connector right? You could probably use a test light on the connector to see that power is getting from the light switch to the cluster.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-10-2019, 10:49 PM   #12
Foureye71
Foureye71's Avatar
Re: No Dash Lights
Ill try that tomorrow. Does anyone have a wiring diagram for the cluster connector?
'86 K30 C&C
'89 Iroc-Z
Old 03-10-2019, 10:58 PM   #13
Foureye71
Foureye71's Avatar
Re: No Dash Lights
'86 K30 C&C
'89 Iroc-Z
Old 03-10-2019, 11:02 PM   #14
Curtb1971
Curtb1971's Avatar
Re: No Dash Lights
Not sure if I can get up there during the week, but I'll more than likely be able to head up that way during the weekend, Saturday maybe?
That works, I'm there all day Saturday. Shouldn't take long with a test light and multimeter
Old 03-10-2019, 11:03 PM   #15
Foureye71
Foureye71's Avatar
Re: No Dash Lights
Sweet I sent ya a pm
'86 K30 C&C
'89 Iroc-Z
Old 03-10-2019, 11:12 PM   #16
Boog
laying low
Boog's Avatar
Re: No Dash Lights
This may be of help. If not use the search button for wiring schematics and numerous threads will come up. And VetteVet is one of the wiring gurus on board.
Boog
primer is finer
Old 03-10-2019, 11:17 PM   #17
Foureye71
Foureye71's Avatar
Re: No Dash Lights
'86 K30 C&C
'89 Iroc-Z
