03-10-2019, 11:03 AM | #1 |
Headlight switch removal
I found no setscrew to remove the knob from the post so what is the best way to remove the headlight switch after I unscrew the spacer that threads onto the post?
03-10-2019, 11:49 AM | #2 |
landarts
Re: Headlight switch removal
There is no set screw on knob, reach up behind dash with one hand and press a small button on top of switch, while you depress button in pull on knob and the whole shafts will release . Then screw off retainer ring on font and switch will come out of bezel.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
03-10-2019, 11:50 AM | #3 |
If I remember correctly there's a release button on the switch. (Small button with a coil spring under it ) If you push this in and hold it the shaft that the knob is on will pull out of the switch.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
03-10-2019, 12:26 PM | #4 |
Thank you - just figured out the button releases the shaft.
03-10-2019, 02:33 PM | #5 |
20' Daredevil (Ret)
Late reply but y'know the headlights come on when you pull out the knob/shaft, right? Battery should be disconnected to prevent draining it....
03-17-2019, 05:58 PM | #6 |
Glad I found this thread!
Picture for those of us with zero knowledge.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet Last edited by 89AKurt; 03-18-2019 at 02:26 AM. |
