Old 03-10-2019, 11:13 AM   #1
jbgroby
jbgroby's Avatar
OEM/older rear drums
I finished changing out all the front brakes parts including the newer 63 hubs. I inspected the brakes and they look OK, but want to change it all out to new meat anyway. I removed the old drum to see the wear and noticed it was shipped different than the one new replacement. Also the ring is "stapled" to the crown. I've never seen that before have y'all?
jbgroby is offline   Reply With Quote
Old 03-10-2019, 12:32 PM   #2
jocko
jocko's Avatar
Re: OEM/older rear drums
Interesting, have not seen that method before. I wonder if there was a process to replace only the drum ring back in the day or if that was just considered an easier manufacturing method?
Old 03-10-2019, 12:40 PM   #3
jbgroby
jbgroby's Avatar
Well they are OEM, so I'll going to check the shop manual to see if they happen to show a picture.
Old 03-11-2019, 09:13 PM   #4
paulspickupparts
If this came off a GMC Dana rear end they will look like that . I think the offset may be different also.
paulspickupparts is offline   Reply With Quote
Old 03-11-2019, 09:19 PM   #5
jbgroby
jbgroby's Avatar
Yes, I may have to deal with that, these can be turned, but I was wanted new drums. if possible.
Old 03-11-2019, 10:58 PM   #6
raylube
raylube's Avatar
Factory gmc dana drums look like that. Search forums for alternative drums as the offset is not the same as chevy.
raylube is offline   Reply With Quote
Old 03-12-2019, 08:52 AM   #7
jbgroby
jbgroby's Avatar
Thank Ray, I found the discussion and now know what to hunt for Raybestos 2067
