Old 03-11-2019, 09:19 AM   #1
Nodnarb76
Nodnarb76's Avatar
Oil Pressure sender block off behind intake manifold.
Dumb question.
I have noticed an oil leak from my un-used oil pressure sending unit behind the intake manifold.
I would like to just remove it and use a bolt/plug to put in it's place.
As long as it is an M16 1.5 bolt should work right?
I was looking at this:
https://www.amazon.com/gp/product/B0...3NK9WU6R&psc=1
Would that work?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 03-11-2019, 09:22 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Oil Pressure sender block off behind intake manifold.
It should work but I'd put a copper washer under it like the drain plug uses
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-11-2019, 10:03 AM   #3
Nodnarb76
Nodnarb76's Avatar
Thank you,
It's funny how you second guess yourself when it comes to your own ride.
I figured it would work, just wanted to make sure there was not a reason not to use this.
Old 03-14-2019, 06:38 PM   #4
LH Lead-Foot
Looks like your'e getting 2 in the box for $13. I agree on the copper or aluminum crush washer used on import trucks.
If you in a hurry, you could cut the top off, drill, tap with NPT, then install a brass fitting with a little pipe dope. That way you can drive it until the flying drone shows up on the front porch. But, you have found a decent better looking option on the big A.
Also, the old school oil sender socket works great, same size. At least my SnapOn one does.
Being curious, is it leaking at the bakelite plastic top, where it's crimped into the metal base? A good flash light and a mirror on a stick would tell for sure. Anythings possible when it come to leaks.
I have three different "UV" lights and a case of "UV" oil dye. But that's how I roll because it's just sitting there on the self.
You may want to clean with a spray of cleaner, start, run and re-check...
Removed
LH Lead-Foot is offline   Reply With Quote
Old 03-14-2019, 10:58 PM   #5
ls1nova71
ls1nova71's Avatar
This is what I did when mine started leaking years ago, works perfect. Generally they will leak through the sender where the plug attaches and will seep over time, but without anything plugged into it you notice it a lot sooner!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
