Junior Member
![]() Join Date: Oct 2017
What is this and where does it go?
Can't remember where this goes or what it is for, but I think it goes on the engine somewhere. 69 C-20 Longhorn, 396, SM 465. I'm sure someone can
help me out Thanks Greg
Greg 69 Longhorn 396, 4 Speed SM 465, PS, PB, No Air |
laying low
![]() Join Date: Mar 2001
Re: What is this and where does it go?
Plug wire separator.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver 'primer is finer' Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Junior Member
Boog your right. Looking at my pictures I also found where it goes now.
Thanks Greg
![]() ![]() Join Date: Feb 2009
Right on, where did you place it? I pulled one of my truck a quarter century ago. Best I can come up with is the 2nd lower bolt hole from the front on the RH valve cover.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Junior Member
I have a picture of it on the rear lower valve cover bolt on Drivers side. Not sure that is correct though, but that's where mine was.
Greg 69 Longhorn 396, 4 Speed SM 465, PS, PB, No Air Last edited by Longhorn 69; 03-12-2019 at 10:51 PM. Reason: trying to add the picture |
My first instinct was that's exactly where it goes. But I can't make sense of it. Seems it would take two wires. By the looks of this placement, it appears just one wire, routed from behind the valve cover. I know the old wires were pretty thin, maybe it retains just one?
Junior Member
That's the location my pic shows. Yes I agree, pretty small openings for the wire. I think just the one wire also. I am going to try to find some small grommets to slip in the openings to help protect the wire but probably not enough room for them and the wire both.
| Bookmarks |
