68 C20 cab/f-clip to a 83 C30 running gear
Hello,
I've got a 68 C20 farm truck with an average body, inline 6, 4sp, 2wd, that I'd like to swap onto an 83 C30 454, 4sp, 2wd. Would this be a major headache swap or would it be a fairly easy idea to pull off? I'm planning to build a new flat bed to go on it so the 68 bed won't be a problem. I looked around but most of what I found was music videos or somebody explaining his plans and aspirations, but nothing about what problems they did or didn't have to over come. I'm sure this has been done. Richard
Lead, follow, or get out of the way! |
![]() Join Date: Aug 2004
Re: 68 C20 cab/f-clip to a 83 C30 running gear
I'd put the front suspension cradle and running gear on your 68 frame. Use the booster/master/prop valve from the 83. Most all of this should bolt up.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
