Seat swap question
Will a 66 C10 seat fit in a 67 C10 ? .... A guy has a nice 66 seat and I thought I could recover it if the seat fits .... If not I may go another route
Re: Seat swap question
Do you have any of the hardware from the original 67 seat?
No ... My trucks original seat was long gone ....
Ah ok.
9 times out of 10, the "feet" of the brackets don't line up elevation-wise with the floor pan. But if you can get your hands on a set of 67 brackets/ sliders, you can probably weld those feet to your 66 sliders and have a functioning bench. On second thought, the fit is also determined by the offset of your brackets side to side. If you're up to go look at it, take a measurement of the distance from your front driver's seat bolts to the front passenger's seat bolts and see if the 66 bench has the same measurements for it's sliders. I took a chance with a square body bench seat and lucked out. Slider offset was the same, so I welded the 67-72 feet to the squarebody sliders. |
![]() Join Date: Feb 2019
Measure the holes in your floor, and ask for the dimensions of the holes in the tracks and compare.
