Old 03-14-2019, 09:37 PM   #1
Red66C10
Ball Joint Taper
Got a 66 C10 and want to know what the taper is on these ball joints Upper and lower.
I have a 7 degree reamer and don't know if that will work for both upper and lower? Will it work for the steering joints too?
Red66C10 is offline   Reply With Quote
Old 03-19-2019, 06:49 AM   #2
PGSigns
PGSigns's Avatar
Re: Ball Joint Taper
What are you trying to do? What do you need to ream?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-19-2019, 10:45 PM   #3
AZ 67 C10
AZ 67 C10's Avatar
I increased the taper on my spindles to accept larger tie rods (73-87) since the rest of my suspension was 73+ and my spindles were 67-70. I cant speak for all the different years and suspension components but my setup was a 7 degree taper. There's some math involved to figure the degrees of taper so don't quote me on it being 7 degrees since I could have totally done the math wrong.. In the end I took it to a machine shop since my tapered bit was chattering when I tried to do it.
AZ 67 C10 is offline   Reply With Quote
