Old 03-15-2019, 09:25 AM   #1
ParZimmerdahl
1966 Chevrolet truck C10, TH400 cooler lines
Hi,
I am in a need of new trans cooler lines but canīt find any for a c10 with a th400 trans.
Do you know if and where I can find any?
Thanks for any information!
ParZimmerdahl is offline   Reply With Quote
Old 03-15-2019, 02:16 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 1966 Chevrolet truck C10, TH400 cooler lines
Since I'm fairly sure the 66 didn't come with the TH400 I would imagine that making them would be in order. Or go with stainless flex lines. Again measuring to get the right length. I'd use a piece of copper wire ground wire to do that or get a 1/8" solder roll and use it. Not hard to crimp tubing either.
Old 03-17-2019, 07:54 AM   #3
ParZimmerdahl
Thank you, I was bit unclear in my question, actually its a c25 which I converted into a c10, and I believe this truck came with a th400.
But as you said, I probably have to make the tubing myself as I can’t find any reproduction of these.
Old 03-17-2019, 11:47 PM   #4
Captainfab
60-66 Nut
The '66 C20's were available with a TH400 from the factory. Yes you will likely have to make your own lines.
