03-15-2019, 06:19 PM | #1 |
1960 Upper Steering Column Bearing Replacement
Hi - I searched and searched but cant find anything on the 60 era steering column upper bearing. I will need to replace mine and wanted a picture of the correct one. I find the 64 and later ones all over with the plastic TS switch. I need the right picture of someones column. I don't think this truck had factory turn signals as unit has an aftermarket era correct switch attached to the column.
I want to be prepared when I pop the wheel off... Thanks!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
03-16-2019, 07:40 AM | #2 |
Re: 1960 Upper Steering Column Bearing Replacement
Classic Industries list a 1960 - 63 upper column bearing assembly E1175. In my old catalogue nothing is showing for anything newer.
03-18-2019, 07:06 PM | #3 |
I already have a bearing. Want to see how its all held together. These don't have the normal plastic switch with the upper bearing in them.
03-18-2019, 10:37 PM | #4 |
I would just go ahead and pull it apart. You will probably see how it works then. If you have a spring at the bottom of the column it will be what pulls the shaft down and takes the looseness out of the bearings, kind of like an old bicycle fork.
03-20-2019, 05:55 PM | #5 |
I pulled it apart and it was self explanatory. It appears the rag joint also helps with slop. Will be replacing that too. But now I don't have a floppy upper steering column!
