Frame question
I have a 72 Chevy truck a 4x2 shortbox. I have a different frame year because it has front drums and 6 lug wheels. How can I tell what year the frame is? The last owner did not know.
member #16
![]() Join Date: Dec 1999
Look on the driver side frame just ahead of the engine tower, you will find a number a letter and some more numbers stamped in the frame. The first number is year made the letter designates plant of manufacture and the rest are production no's
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
My '72 GMC frame has the date stamped on the passenger side frame rail about a foot ahead of the rear cab mount. Maybe the '72 cab has been installed on an earlier chassis???
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
its all about the +6 inches
Most I have seen were stamped right beside the steering gear box, on the very top viewable looking down from under the hood. (Does this make sence?)
Who has my frame number pic? I don't have it since I am not on my computer and they are no longer networked together. ![]() |
Here we go...this is what I was talking about. (found it in another thread)
That is where the frame VIN should be...I think the 67's did not have any numbers. |
is it possible that they switched out the brakes? someone wanted the 5 lug so they switched out the front and rears...???
70 longbed 496/th400/Ford 9" |
Merciless Butcher
Didn't all 4X4's have six lugs even in 71 and 72 even when discs were factory installed? I have a 67 frame and it is stamped. It's just farther back, about 4 inches in front of the left front cab mount. This could have varied between assembly plants.
Your Bought And Sold....I Got Your Soul! Last edited by gonebad2; 11-26-2003 at 02:43 AM. |
But his is 4X2. and it has drums up front.
Merciless Butcher
Oh man.....I gotta cut back on the oxycontins...I don't know why I was thinkin 4X4. Thanks longhornman
Your Bought And Sold....I Got Your Soul! |
Thanks for the help everone, This sight is very helpful. I just bought this truck its my first one in the 67-72 range.
