Old 03-17-2019, 10:09 AM   #1
damnyankee36
damnyankee36's Avatar
Steering Column Pics Request
I'm working on connecting the column wiring to the main harness. I'm not sure exactly how the turn signal harness is routed at the left side of the column. Comparing what I have to what's in the assy manual I'm not sure of the orientation of the connector.
You can see what I have using the old harness as a guide. It's pretty much conformed for the main harness connector to be oriented as shown but the assy manual shows it the other way. Plus, the turn signal harness clamp is different.
My main harness connector was toast as was the clip that attaches it to the bracket. I'd also like to know which hole I should use if I ever find a connector. The manual shows the outer hole. Also not sure if it should be bent like mine is.
Anybody have a pic they can share of an original harness of this area?
damnyankee36 is offline   Reply With Quote
