Old 03-17-2019, 02:23 PM   #1
jlampka
1972 GMC Radiator Leak - 402 ci
Hello again - I noticed a crack in the upper area of my radiator that is leaking fluid after the truck reached temperature and I saw a few drops on the driveway. Anyone know if this can be brazed or repaired and then pressure tested and used again? All replies welcomed! Thank you! See photo
jlampka is offline   Reply With Quote
Old 03-17-2019, 04:09 PM   #2
Smitty
Smitty's Avatar
Re: 1972 GMC Radiator Leak - 402 ci
I would think a good radiator shop could repair it. Or an older more established shop might have a tank laying around that they could put on it.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 03-17-2019, 05:35 PM   #3
RustyPile
RustyPile's Avatar
I agree with Smitty.. It's an easy repair for a good radiator shop..
RustyPile is offline   Reply With Quote
Old 03-17-2019, 05:39 PM   #4
p0508
A shop can fix it, but so can high temp high psi epoxy, the stuff that comes in the syringe you can buy at the parts store. I punched a hole in a 1000rwhp corvette radiator years ago and my "quick fix" was some of that epoxy. It's still holding to this day.
p0508 is offline   Reply With Quote
Old 03-17-2019, 06:31 PM   #5
hjewell2
hjewell2's Avatar
Yes that can be repaired.
hjewell2 is offline   Reply With Quote
