03-18-2019, 12:58 AM | #1 |
Radiator drain plug HELP!!!
Took my ‘70 out today around to the gas station to fill her up and air up tires. As I waited for air compressor to be freed up, I got out and popped the hood to look for any leaks and boom! My drain plug blows out. I went to autozone around corner to grab a drain plug, they give me a 1/8 plug, too small. I go return it and the 3/8 is a special order item. So I grab a 1/4 drain plug and it’s too big! I looked up the size/specs and shows that 1/4 drain plug should be the one. Am I missing something? Any input is appreciated....
1970 CST/10 LWB 350 1984 Blazer |
03-18-2019, 11:10 AM | #2 |
Re: Radiator drain plug HELP!!!
I'd have a hunch that there are lot's of radiator shops in Arizona. I would try them for a correct fit.
03-18-2019, 11:30 AM | #3 |
Who Changed This?
Is the plug you got straight pipe or tapered pipe? Maybe they sold you a straight pipe version?
03-20-2019, 10:04 PM | #4 |
it should be a 1/4"NPT pipe plug,(National pipe threads) it is physically bigger than 1/4 " and has tapered threads,It should be brass, I usually install a 1/4 " petcock in there so you can just loosen a knob and drain the radiator that way, it gives you control ,https://shop.advanceautoparts.com/p/...1106/5701643-P
