Cause the Chicks DIG IT!!
Stupid lights!!!
STupid.....LighTS!!!
Does anybody know if there is a main ground for the turn signals and dash lights inside the cab on a 71 chevy halft ton? when i turn on my left turn signals they work fine, when i turn on my 4 ways they work fine, but when i turn on the right side both lights in back blink the front left side marker light blinks and all the dash lights blink I've replaced the turn signal switch, the light switch and pulled off the rear wiring harness and there aren't any faults. I've figured out that the rear left turn signal is blinking through the brown wire which is lights???? Any ideas ???? HELP!!! ![]() |
Merciless Butcher
I think there is a black ground wire with a clip that slides onto a piece of sheetmetal under the dash. Make sure the bed has a good ground to the frame and the headlight switch is grounded to the dash. There is an external star lock washer that goes under the nut that retains the headlight switch.
Your Bought And Sold....I Got Your Soul! |
I need a brake!
Did you replace the flasher, and check ALL the bulbs- especially any that are not working?
JP MEMBER OF THE DISCS UP FRONT CLUB 1971 Chevy C10 |
I've torn all the wires basically out from underneath the dash. What i get is that the wires that go into the firewall to go to the rear is the dark green should be the only one flashing with right turn signal on, but i get the brown which is the running lights circuit flashes too. I traced the brown wire back and it runs into the headlight switch. I disconnected that there and the damn lights still blink!!!
Firefighter
Try changing your flasher relay, that could be the problem.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Flasher relay? I've found out with my multimeter that i'm getting continuity from the flasher out socket on the fuse box to the dashlight power wire going into the fuse box. How this is happening i have no damned clue. All the wires look good as in no frays or nothing. As in the flasher realy are you talking about the flasher in itself?
