Old 03-19-2019, 12:28 AM   #1
stsalvage
Scrapper 1
stsalvage's Avatar
1972 C20 Dana rear end
I have a 1972 C20 3/4 ton truck My truck is a light duty 3/4 ton It came with a 350 engine and a th350 trans with a dana 3/4 ton rear end the rear end had the type of drums that slide off I was told there floating drums instead of the One you have to pull the axles. It has 3.73 gear in it. Not so good for towing It has a Peg leg meaning one wheel turns when you step on the Gas.
I'm in need of know which rear end I have is is a Dana 60 or a Dana 80 o9r is there a Dana 70
stsalvage is offline   Reply With Quote
Old 03-19-2019, 04:43 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 1972 C20 Dana rear end
It should be on the web of housing.....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-19-2019, 05:16 AM   #3
b454rat
Most likely a Dana 60
Old 03-19-2019, 05:17 AM   #4
Killer Bee
Killer Bee's Avatar
this may clear things up a little
https://en.m.wikipedia.org/wiki/Dana_60
Dana 60 rear axle
The Dana 60 rear axle was first introduced in 1955 as a full floating axle in Ford F-250's and is still used today.
Manufactured in both full float and semi float variations. The semi float axles have GAWR up to 5,500 lbs and the full float axles were rated up to 6,500 lbs.
Full floating variants are common while Semi-floating axles exist, but are less common. Axle spline count varies, with 30 spline being the most common.
For 1967, GMC introduced a semi-float Dana 60 to accompany the optional 396 big block engine in their C15 (half-ton) line of trucks. This axle used a traditional Dana 60 center section (typically cast with "60-2" in the top center position) but with Dana 44 shaft bearings and brakes. Open differentials as well as the Dana Powr-Lok system were available.
Old 07-23-2019, 06:58 AM   #5
mike16
so for those 67 gmc big block 1500's did they have 6 lug or 8 lug axles? I come across 3/4 ton versions with the 8 lug axles all day long
mike16 is offline   Reply With Quote
Old 07-27-2019, 10:52 PM   #6
Mike C
Mike C's Avatar
They had a 6 lug semi-floating axle Dana 60.
Your "light duty" Dana 60 is the heavier duty option in 67-72 3/4 ton trucks. The HO52 was rated at 5200# GAW and the 60 is 5500 GAW. Nothing light duty about that.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
