Old 03-19-2019, 05:31 PM   #1
BBCamaro
BBCamaro's Avatar
Electrical question
Hi hope someone can help me out. I have a 71 c20 the problem I’m having is sometimes the left Brake light won’t work. But if I turn on my left turn signal then cancel it the brake light will start working for a bit.. I’m definitely not a beginner working on vehicles but this has me stumped.. any help would be greatly appreciated.. thanks
BBCamaro is offline   Reply With Quote
Old 03-19-2019, 06:05 PM   #2
Wrenchbender Ret
Re: Electrical question
Seems like you have a bad turn switch. The brake lights go through the turn switch. If the contacs are loose or sticking they don't go back to the center position all the time.
Wrenchbender Ret is offline   Reply With Quote
Old 03-19-2019, 06:12 PM   #3
WorkinLonghorn
WorkinLonghorn's Avatar
nvm
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 03-20-2019, 05:17 PM   #4
BBCamaro
BBCamaro's Avatar
Thanks!!! That’s what it was I noticed this morning if I didn’t have brake lights I simply moved the turn signal lever and I did.. now to fix that.. thanks again
Old 03-20-2019, 08:37 PM   #5
lutronjim
Had a similar problem several years ago. Sprayed the crap out of switch with contact cleaner (DeOyx) and its been working ever since.
lutronjim is offline   Reply With Quote
