Old 03-19-2019, 06:06 PM   #1
kens65fb
Ignition switch help please
Currently my keyed ignition switch is located on the crap steering column installed by previous owner.
The old ignition switch is still mounted to the instrument bezel, but no wires are connected.
I want to go back to the ignition switch on the dash, not on the steering column.
Here is a pic of the back of the switch, I see where the battery wire is connected, where the ground is connected, and where the ignition wire is connected, and the accessory wire connects to the switch.
My question is what wire goes to the top most terminal, looks like "SOL" imprinted underneath the connector ??
kens65fb is offline   Reply With Quote
Old 03-19-2019, 07:03 PM   #2
Rolland
Re: Ignition switch help please
That would be the solenoid terminal.
Rolland is offline   Reply With Quote
Old 03-19-2019, 10:14 PM   #3
Wrenchbender Ret
Yes. It is a purple wire goes to the Starter.
George
Wrenchbender Ret is offline   Reply With Quote
Old 04-08-2019, 06:05 PM   #4
kens65fb
I have looked everywhere, I can't find the connector "pigtail, that plugs into the original in dash ignition switch. It seems that the 67-79 C-10 pigtail is widely available, but I can't find one for 64-66.
Does anyone know who sells or reproduces this connector ??
Old 04-08-2019, 08:52 PM   #5
PGSigns
PGSigns's Avatar
Surf through the ads in the for sale section. There are a few threads where folks are parting trucks.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-08-2019, 09:41 PM   #6
damnyankee36
damnyankee36's Avatar
If you can't find a connector there's no reason why you can't use some insulated female spade terminals to connect the wires. Not pretty but perfectly safe and secure.
damnyankee36 is offline   Reply With Quote
